Results 1 to 2 of 2
Thread: installing rack spacers help
    Dave
    The Ghetto
    Default installing rack spacers help
    hey guys ive got a screw on lock spacer and was just wondering whether i had to remove the inner tie rods from the boot and install it there?
    where exactly do i install it? sorry for the stupid question
    Thanks
    Oversized 86
    hey mate,
    the lock spacer has to bolt to the end of the actual rack...
    so yes, you need to take off the inner tie rod...
    AJPS Extra Lock Spacers
    Fitting Instructions
    Unbolt both tie rod ends
    Bolt the screw-in lock Spacer on PASSENGER side of steering rack ONLY
    With tie-rods off turn lock-to-lock and count the turns
    Then half that amount and turn the wheel from full lock to the half-way point
    Your rack will now be centered
    Now bolt your tie rod ends back on using loc-tite or similar
    Get a wheel alignment
    Recommended wheel alignment specs for aggressive driving:
    3.5 + caster
    2 – camber
    2 total toe out
    NB: THIS ITEM IS FOR RACE OR OFF ROAD USE ONLY
    NB: Longer control arms (corona, sigma, rose jointed are highly recommended or you may need to cut 8mm off your outer tie rod ends (some racks only)
    thats copied directly from the AJPS website
  • Similar Threads
    1. XT130's with P/S rack, longer rack ends?
      By Jimmee1990 in forum Technical - Questions
      Last Post: 6th December 2011, 07:31 PM
    2. [melb] rack ends and rack bushes
      By shakes in forum Car Parts For Sale
      Last Post: 10th May 2010, 09:28 PM
    3. Replies: 1
      Last Post: 3rd November 2009, 07:52 PM
    4. rack end and rack bush for ae86 power steering rack
      By quoccy in forum Cars or Parts Wanted
      Last Post: 28th June 2008, 12:58 PM
    5. rack spacers
      By flegburt in forum Technical - Questions
      Last Post: 5th November 2007, 11:56 AM
