Results 1 to 6 of 6
Thread: Greddy Roll center adjuster
    Tom
    SOR
    Default Greddy Roll center adjuster
    Found this while browsing can anyone tell me how it work? doesn't look like your typical RCA.
    http://www.rhdjapan.com/jdm-low/Trus...ter-AE86-56341
    These are probably better than your normal style of RCA for AE86. It replaces the ball joint end that connects to the steering rod, there for pushing the Lower control arm down like your typical RCA spacer. This is cleaner and probs pits passable ie; they won't notice it. Eitherway, both work the same.
    EDIT: Maybe a good thing for having this is saving weight!
    Tom
    SOR
    Ahh ok now it all makes sense. I think this is exactly what I need because normal spacer RCAs foul my brake rotors and since this thing actually connected to the steering rod it should be perfect.
    Although a little expensive I think I might get one.
    yer, sounds worth it.
    Jonathan
    When I first saw the picture in that link, I thought someone at Trust must have stuffed up the design. Unlikely. But looking into it further it would seam to me that someone stuffed up at rhdjapan and posted the wrong picture. More likely.
    See the proper website here:
    http://www.trust-power.com/06sus_spr...center_aj.html
    Their roll centre adjuster for AE86 is the traditional spacer as we know them.
    The picture in the first link is for Nissans and other stuff. And if you did use that style of lengthened joint, you would probably also have to use these: (depending on model)
    http://www.trust-power.com/06sus_spr...angle_adj.html
    Quote Originally Posted by Jonny Rochester View Post
    Yer, I didn't bother to look. I thought it was possible they made them and that's also true, you will have to run lowered tie rods as well. ghey with aids.
  1. TRD built AE86 positive roll center adjusters
    By Sam-Q in forum Technical - Questions
    Last Post: 12th December 2011, 05:48 PM
  2. t3 roll center adjusters $50 chermside
    By milan_ke70 in forum Car Parts For Sale
    Last Post: 3rd December 2011, 09:51 AM
  3. neg camber roll center adjusters
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 3rd October 2009, 05:36 PM
  4. Replies: 3
    Last Post: 21st February 2009, 07:14 PM
  5. Where to buy Negative Camber Roll Center Adapters/Adjusters
    By AE86.cn in forum General Topics (No Technical Questions)
    Last Post: 6th March 2008, 02:02 PM
