Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Front Brake Upgrade: RX7 4 Piston caliper and 276mm Rotor
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    Default Front Brake Upgrade: RX7 4 Piston caliper and 276mm Rotor
    AE86 Brake Upgrade Using RX7 FC3S Calipers.
    Items required:
    Brake Calipers, 1990 Approx RX7 Series 4/5 Turbo $135 Calipers, $160 to rebuild
    2001 Mini Cooper S Rotors, 276mm dia, 22mm thick, 64mm centre hole (same as AE86) DBA P.N. 542 RDA P.N. 7352S (slotted) $285 Pair
    Custom made bracket to fit Calipers to AE86 Hubs
    4x M12 x 30mm Cap Head Bolts
    8x M12 x 35mm Cap Head Bolts
    First, brake adapter bracket.
    Using CAD drawings from Twinky on Toymods , brackets are milled from solid steel on CNC. These were made cheaply by some guys at work, but with the drawings I think any fabrication shop could do it. Cad drawings are available **** Here ****
    Free Viewer/Printer for DWG and DWF > Here
    Second, modify Mini rotors
    The rotors have a chamfer on the inside where they locate on the hub, a new chamfer needs to be made on the opposite side to fit over the AE86 hub, this can be done on a lathe in a few minutes.
    Third, modify Sprinter hub
    Because the disk is so much larger, I replaced the standard M10 bolts that mount the disc on the hub with new High Tensile M12 items, to the holes on the hub were drilled out to 10.2mm, and re-tapped at M12. Then, using the AE86 hub, re-drill holes in rotors to mount onto reverse of hub, PCD is about 87mm but having the old rotors and hubs you have a template.
    Then, assemble the whole setup. Original AE86 brake lines can be used, or replacement braided units (ex. From AJPS $180) sweeten up the system. Original master cylinder can also be used, with a T-18 rear end my pedal felt a bit squishy at first, then firms up. Nissan Skyline R32 non-ABS is now installed and pedal feel is much firmer and stronger. Master bolts onto original booster and I bent original hard lines to suit. Had to shorten one hard line and re-flare but it wasn't difficult. Passed QLD Mod plate test with ease, stopping from 60km/h in 19m with Bridgestone RE001 195/50 Tyres.
    Clearance is good with 15’’ SSR wheels, about 1cm to the outside of the rim. There is a clearance issue with the spokes so I ran a 7mm spacer. Currently running Watanabe RS 15 x 8.5 -6 and running an 11mm custom spacer. Wheels without dish or wheels designed for more modern cars (Rota Grid 16x8 +10 for Example) fit without any spacers.
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Awesome write up Oly.... the easiest and clearest guide I've come across so far..
    BENT MECHANIX - Garage 20:
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    good article man, props
    MY JZX83 (clicky)
    Oversized 86
    good write up...however i think your prices are alittle wrong...
    the calipers are definately more than $160 to rebuild...
    Kevin
    Queensland
    North Lakes
    hey there does ne one have a set of these not on there car yet in brisbane my uncle owns his own cnc machine company and i can get them made up for next to nothing for me hehe
    Oliver
    Logan Shire
    Quote Originally Posted by Oversized 86 View Post
    When I had my Calipers rebuilt, its was $80 per. That included new seals, rebuild labor and cleaning/painting, pistons were prefect.
    Oversized 86
    thats bullshit cheap hey...
    how long ago did you have that done?
    Site Supporter Javal's Avatar
    Josho
    Generally speaking, the pistons are the expensive part of having your calipers rebuilt. If they're fine, It's a cheap exercise like it was for Oly. If they all need replacing, the bill gets quite large.
    Oversized 86
    mmm...thats probably why the rebuild of mine cost well over $300
    Coolangatta
    Hey Oly. Cheers for the write up again. I was looking for it but obviously deleted when the old boards went. If you want them for reference Hen sent me an updated version of files based on your drawings/design. I haven't looked at them yet, been otherwise occupied, so I don't know what was changed.
    Chris.
    PS. Cost me $80 for two rebuild kits from PBR, took a couple of hours to clean (most of the time), paint and rebuild.
  1. Replies: 4
    Last Post: 13th May 2012, 11:17 AM
  2. Brake Adaptors 294mm Rotor RX7 calliper
    By Rip it in forum Car Parts For Sale
    Last Post: 20th August 2009, 09:22 PM
  3. RX7 adapter for bigger rotor's (276mm) 15 Rim
    By dave2221 in forum Car Parts For Sale
    Last Post: 25th April 2009, 04:15 PM
  4. Mazda FC 4 Piston Calipers Brake Upgrade!
    By ta22max in forum Car Parts For Sale
    Last Post: 5th September 2008, 12:21 AM
  5. AJPS rx7 caliper/civic rotor plates
    By delazy in forum Car Parts For Sale
    Last Post: 24th August 2008, 10:14 PM
