Results 1 to 10 of 10
Thread: Rose Jointed LCA's, pics?
    Calvin
    Kilsyth
    Default Rose Jointed LCA's, pics?
    hey,
    going to make my lca's adjustable with rose joints and was after a few pics for some ideas and see some designs. already searched a bit but nothing really came up.
    Cheers, Calvin
    T18 in the build
    Jonathan
    In both these designs I think the new ball joint has a left hand thread. Or some part of it does. So you have a tricky adjuster with inner and outer left and right threads, so it is "on car" adjustable.
    The first one is the original arm cut of course.
    The second is totaly custom from scratch.
    Kevin
    Queensland
    North Lakes
    fuck that second set is sick
    Mt Macedon
    Have a search on toymods, I seem to remember "EvoSti" whacked up something about making rosejointed LCAs. May even be on the old forums.
    Calvin
    Kilsyth
    yeh searched on toymods but didn't really come up with much.
    with the bush that goes through the rose joint obviously you make it so that it fits tight into the crossmember but is it important that the rose joint can't slide on that?
    if so would it be a two piece thing that that you can slide them in the rose joint and then fit into the crossmember? if you know what i mean...
    T18 in the build
    Davey & Riki-lee
    South Australia
    Seaford SA
    that 2nd set would cost alot!
    Our introduction - Click here
    Senior Member 20v ae71's Avatar
    Dillon
    where would you buy the rose joint that replaces your ball joint? it'd have to have a taper on it right? im talking about the the bit that connects to your steering arm btw
    Veteran slydar's Avatar
    Dimitri
    re above.
    first, no one calls them rose joints really.
    the one at the inner pivot (same style used on the rear 4 link ect) is called a "rod end"
    the outer one is called a spherical bearing. its exactly the same style bearing thats used in a strut top, the bit with the taper is a separate part.
    you can buy them ready made in a few sizes, probably nothing that would work with an 86 steering knuckle, but the same places sell the tapered "ball joint reamer".
    Dimitri
    lol well that set used rod ends both ends which is a bit odd, but anyway yeah as above.
    you can also buy rod ends with that part built in, but not with a taper.
    best place to get them is u.s mail order places.
    Senior Member 45aken's Avatar
    Marko
    Most bearing shops can get them in.
    not cheap.
    Hokey, are you talking about the rod end that goes into the cross member sliding around?
    you machine up spacer rings which center the rod end between the cross member mounts (2nd pic). Also there is no "bush" that passes through rod ends, it'll more than likely be a 8.8 bolt that fits flush.
  1. AE86 Rose Jointed LCA's, Warragul Victoria
    By Corolla52 in forum Car Parts For Sale
    Last Post: 6th July 2011, 05:11 PM
  2. Replies: 5
    Last Post: 25th March 2011, 03:08 PM
  3. Rose Jointed 4 Links
    By Eircamae86 in forum Cars or Parts Wanted
    Last Post: 27th March 2009, 06:05 PM
  4. will rose jointed LCA's fit in E7s with stock struts?
    By mtgg85 in forum Technical - Questions
    Last Post: 14th July 2008, 05:15 PM
