Results 1 to 10 of 19
Thread: auto 2 manual parts list?
    Glenn ke_70's Avatar
    Clay
    Barossa!
    Default auto 2 manual parts list?
    im converting a 81 xx ke70 corolla from auto to manual
    i think i got most of the parts lined up but can some one just list a parts list
    would be helpful
    Jonathan
    K40 manual gearbox
    gearbox crossmember
    metal plate between gearbox and engine
    flywheel and bolts
    clutch
    clutch cable
    pedal box, or clutch pedal at least
    Stick will come through the hole, but it may need to be modifyed. Or parts overed over.
    May need tailshaft also.
    Kieran
    Quote Originally Posted by Jonny Rochester View Post
    K40 manual gearbox
    gearbox crossmember
    flywheel and bolts
    clutch
    clutch cable
    or k50 gearbox
    Veteran Konakid's Avatar
    Henry
    Eastern
    Good post Doris, + reps.
    Dan
    Vic
    Western Subs
    speedo cables are different auto to manual
    the tailshaft manual and auto will be different so you can either press out the piece you need (the coupling that joins the diff) or
    if your lucky like me and had a doner car steal it from that
    also you'll get stuck with the same thing as me where you'll need a cup where the clutch cable goes through im trying to work out a simple and good fix but haven't found anything as yet
    PM me if you have any questions - also the pedal box is a prick to pull out enjoy
    . h i t o r i k o .
    Nic
    Mt Evelyn
    how different are the trans tunnel from auto to manual? im doing a manual conversion on ae71. so wondering how different the hole is for the shifter?
    nic
    Junior Member prodigy's Avatar
    Aug 2010
    Lalla
    Western Cape
    Athlone
    South Africa
    Hi there, sorry for this super late reply...lol
    I too am switching from auto to manual, having trouble mounting the manual gearbox? I see you mentioned gearbox cross member?
    Where is that situated, im new to this...
    Spreading an idea through radiant osmosis....
    ex '98 FIAT Uno Turbo 176kW/362nm@ 1.2bar+Meth
    Rob
    Moorabbin
    About the speedo cable.
    How is it different? Know the best cable to use when converting ke auto to t50?
    Clay
    Barossa!
    auto-manual cable is different where it screws into the gearbox. or its too short can't remember, probley both
    manual k50 speedos fit t50s im pretty sure. not sure how ratios go.
    gearbox crossmember is the bit that holds the gearbox up. it bolts to a rubber mount on the gearbox towards the back.
    you may be able to use an auto one. i remember fileing out my crossmember to suit.
    May 2010
    I have a feeling the auto tunnel is wider in the KE70's then the manual>?
  1. [WA] AE86 stock parts cleanout - Too many parts to list
    Last Post: 8th July 2011, 01:39 AM
  2. Auto to Manual
    By Corona w/ Lemon in forum Technical - Questions
    Last Post: 19th June 2010, 01:25 PM
  3. Auto to manual
    By damo46 in forum Technical - Questions
    Last Post: 16th August 2008, 07:35 PM
