What conidition was the rack in when you put it in? It probably needs new rack ends, tie rod ends, and new ball joints wouldn't hurt.
hey i have swapped my power steering rack and column for a non power steering setup and it seems to be a bit sloppy i have the powersteering arms still on could this be making it rough to drive?
what do you mean by sloopy?
did you put new tie rod ends on the non-power steering rack? they could be flogged
the power steering arms will make the steering a little bit heavier but give you more lock than non power steering arms
oh ok so putting a non powersteering rack on powersteering arms should not be a problem? nah i didnt replace the tie rod ends they looked ok but yer they probably not
