Results 11 to 20 of 29
Thread: mr2 aw11
  1. #11
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    casting is the pouring of molten metal into a cast.
    grain structure is the same everywhere in the piston. this gives an equiax grain structure that that has no strong points. it will hold together but when put under enough pressure it will break.
    forging is where metal is heated to a solidus state (highest temp possible before liquidisation) and then forced into shape.
    when refering to pistons this is done by a mechanical press. this gives an elongated grain structure around the surface of the piston which holds together much better when under pressure.
  2. #12
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    i remember reading a thread on the old dc? someone that actually tested the pistons. i cant rememeber how they were formed. but i remember they werent forged.
    still definatly stronger than GE standard bottom end though. just not forged
    FTP.
  3. #13
    Dan/Rio
    Randwick
  4. #14
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    Not forged. Hyperetectic.
  5. #15
    Jonathan
    That is all well and good. But can you look at a piston and know by the flash marks wether its forged or cast?
    Also, is there any Toyota sourced info stating which pistons are forged or cast? (club4ag does not count).
  6. #16
    Damien
    Brissie
    ^it's pretty obvious really.
  7. #17
    Jonathan
    How so?
  8. #18
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    my advice is buy a rearcut from a supercharged MR2 (AW11 4AGZE)
    use aftermarket ecu (adaptronic,microtech,motec etc) to get rid of the AFM as the mr2s use this standard then u can tune it to run as much boost as you see fit without making the ecu shit its pants and start crying
    buy turbo and manifold
    whack it in with the box from the rearcut as ive been told the s/c versions have the LSD box
    thrash it
    for wheels, from memory the aw11 have a 4x100 stud pattern, so thats a start
    the one my cousin just bought has 4x100 to 4x114.3 spacers on it so if you want to do that then you must sacrifice in offset
    thats about all i know
    hope i helped
    MY JZX83 (clicky)
  9. #19
    yep 4x100 pattern. bit of a pain as most 4x100 is fwd poo. nothing made really wide in the aussie land that is 14-15inch
  10. #20
    Veteran Rice86's Avatar
    Richard
    Liverpool
    nice info guys, toymods is a bit gay no offence, hard to find the info im after, and also cant register hahah
    but again, thanks, really is helping with the brain storming
    dose
  1. Aw11 mr2 s/c - syd
    By wideslider in forum Cars for Sale (Toyota Only)
    Last Post: 29th August 2010, 01:53 PM
  2. Aw11 MR2 NEEdS TO GO
    By ecko in forum Cars for Sale (Toyota Only)
    Last Post: 24th March 2010, 09:59 PM
  3. Adel aw11 mr2
    By Art Vandelay in forum Cars for Sale (Toyota Only)
    Last Post: 19th April 2009, 09:57 PM
  4. aw11 mr2.
    By timmay in forum Cars for Sale (Toyota Only)
    Last Post: 14th April 2009, 09:45 PM
  5. aw11 mr2
    By redsprinter in forum General Topics (No Technical Questions)
    Last Post: 27th November 2006, 01:34 PM
