Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 35
Thread: r32 brake master
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    Default r32 brake master
    hey guys, i've done the s13 conversion on my car. just like to know if the r32 brake master just bolts on and doesnt require and any mods. also with the s13 conversion is the r32 master a MUST?
    Dan
    Vic
    Western Subs
    i think it makes the baking much better for the price of an oil change and the master you cant go wrong - im wondering is running a bigger booster better also
    . h i t o r i k o .
    Phuoc
    Liverpool
    think was i put the 32 master in with the 86 booster n 86 rubber on the master and when i went to bleed the brake they were soft as, so i took them off and going to bleed the brakes again.
    so its recommended to have the r32 master with the s13 brakes?
    User fantapants's Avatar
    Pat
    if its just the standard s13 single piston stuff then no, its kinda pointless.
    06/07/2011
    Jonathan
    Some Nissan master cylinders have the rear proportioning valve in it (the type that has R on the front port and F on the other 2). In theory, you won't want to use the Toyota proportioning valve at the same time, as that would limit rear brake pressure too much.
    Some R31 masters are 1", some R32 masters are 15/16" and some are 7/8", and they all look the same. And there are many other types also...
    When ever you change to different front brakes, try and measure the piston diameter. Even if you can't use the info, someone else could. And it would make it a lot easier in determining what size master would be good.
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    not a requirement i dont use one
    AE86 THE BEST
    Reeece
    Casula
    I am using the R and F type 2 port version.. With stock brake bias it seems to work really well.. I run front hulix 4 pistons and rears are r31.. I recommend it as braking is of most importance when spirited driving
    Quote Originally Posted by Jonny Rochester View Post
    Pat
    yeah but you are using 4 spots.... for sure the pgrade is a great idea on 4 spots.
    on single piston slides it is not necessary. There is a reason why the s13 needs an upgrade when it goes to 4 spot conversions. it doesnt push enough.
    If you have a mastercylinder that is too big you wll loose any pedal feel and modulation and just have fucking on and nothing at all...
    06/07/2011
    Phuoc
    Liverpool
    mines a 15/16. is it any good?
    Jonathan
    The good thing is, that you mentioned it's a 15/16". Now tell me the diameter of your brake pistons and I can work everything out.
    Otherwise it's just taking peoples word for what feels OK.
  1. part number for R32 non abs brake master
    By Mr Awsome in forum Technical - Questions
    Last Post: 13th November 2009, 09:21 PM
  2. WTB: R32 non abs brake master
    By Mr Awsome in forum Cars or Parts Wanted
    Last Post: 1st November 2009, 01:39 PM
  3. which r32 brake master?
    By dave2221 in forum Technical - Questions
    Last Post: 24th July 2009, 03:32 PM
  4. R32 Brake master
    By slideways in forum Technical - Questions
    Last Post: 5th February 2009, 12:38 PM
  5. WTB: R32 Non ABS brake master cylinder
    By Sparkle86 in forum Cars or Parts Wanted
    Last Post: 20th November 2007, 11:17 AM
