Results 1 to 4 of 4
Thread: Cams and dizzy question
    Exclamation Cams and dizzy question
    Hey fellas,
    Im getting some cams for my small port 16v.
    Do you have to specify smallport and bigport when buying cams?
    Also for 272 and 264 cams with 8+ lift do you have to run upgraded valve springs, or any other modifications.
    Would there be any difference where you run them eg 264 on intake 272 on exhaust?
    And finally is there any difference between a smallport and bigport dizzy?
    Thanks
    Jonathan
    The cams are all interchangeable. They all fit. You can even use exhaust cam on inlet.
    As for setup, of course everything makes a difference. I would choose to put the longer duration cam (272) on the inlet. But you don't have to. Your next choice is lobe centre position, or cam timing. You need a degree wheel and adjustable gears. Or you could just chuck them in anyhow...
    The smallport and bigport dizzy is interchangeable I am told, but not identical.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Dizzy's are interchangeable but quite different in internals. You need to use the dizzy which suits the computer/loom.
  • #4
    Senior Member DearmanKE's Avatar
    Alex
    Northfield
    anyone know the difference with smallport and bigport cams?
    are they the same ?
    are bigport cams a upgrade for a small port, n also is ther a way to tell if uve got big or small port camsin ur small port
    Formerly known as grape_moosha
  • Similar Threads
    1. quick dizzy question
      By s13 james in forum Technical - Questions
      Last Post: 26th November 2011, 12:32 PM
    2. dizzy question
      By pen15 in forum Technical - Questions
      Last Post: 16th March 2009, 07:57 PM
    3. A cams question..
      By --Redwork-- in forum Technical - Questions
      Last Post: 7th March 2009, 11:16 PM
    4. 4k dizzy question
      By mtgg85 in forum Technical - Questions
      Last Post: 14th July 2008, 09:21 PM
    5. Random dizzy Question
      By Vezza in forum Technical - Questions
      Last Post: 11th June 2008, 03:36 AM
