Results 1 to 10 of 12
Thread: tyres rubbing
    Jan 2007
    I have a problem with my rims... they are 15x7 with 0 offset on the fronts i have 195/55/15 and on the rear i have 225/50/15
    both tyres rub. The fronts rub the inner walls when parking etc, and when cornering hard they hit the guards!
    The rears his the guards when the car corners hard or hits a bump....
    What should i do... Get different width and profile tyres or just roll the guards ? or both ?
    It would be great for some usefull advice
    cheers. sam
    Julz01
    Most people have 195/50 15 on the cars and they seem to be the tyre size of choice, I have massive ass 4wd tyres atm on my 15 205/50s at the front and 205/60s at the back, was going to change them to 195/50 but now moving down to 14inch wheels.
    What type of suspension do u have as well? this would also factor into why it is rubbing
    Veteran Bustin_86's Avatar
    Justin
    North-West Coast
    I would slightly reduce the rear tyre profile and flare your guards.
    Also, if you are running cut springs or some other soft rate suspension, you could stiffen this to allievate your problem.
    Hope this helps!
    Justin
    Coolangatta
    Mine scrubbed front and back with 205/55/15s. I've since pulled out the springs and found they were soft lowered fulcrum springs. Since replacing them with Kings I've had no trouble with bumps or cornering. Adjusting your caster a bit might help too. Note that I've used standard height springs because I wanted the longer travel for offroad (rally), however, a stiffer spring would probably have been just as effective as the old springs had heaps of deflection when I leant on them and I can assure you I weight a helluva lot less than a corner of the sprinter!
    Chris.
    Rob
    Moorabbin
    195/45 no rubbing
    Senior Member awang's Avatar
    Zul
    Brunei
    Stone City
    Brunei
    why dont u try 205/50 15, mine using that, n my car sits pretty low, but thats on the rear, front using 195/50 15
    Stefan
    Parkinson
    185 45 no problems and bit of stretch will sit under stock guards and nankang make this size!
    15x7 0 minimal problems um just dont run spacers if you are
    Elite rthy's Avatar
    Leo
    Tulla
    15x7 +11 195/50r15 no scrub (just alil above superlow)
    15x7 0 195/50r15 no scrub until it was dropped to superlow then had scrub all over the place
    Stefan
    Parkinson
    im running 15x7.5-4 with 195 50 do scrum mine sits about 120mm off ground no problems just rolled rears and flared front
    Joel
    Blackwood
    Yep run 195/50/15s all round and you should be fine.
    AE86 4AGE "Slowly but surely"
  1. Rubbing brakes. Rebuild?
    By odessy in forum Technical - Questions
    Last Post: 21st January 2012, 09:55 AM
  2. Tyres rubbing on suspension strut
    By Ke70alex in forum Technical - Questions
    Last Post: 14th July 2009, 10:49 AM
  3. Wheels rubbing issue?
    By narchi in forum Technical - Questions
    Last Post: 6th January 2009, 01:16 PM
  4. Guard Rubbing
    By stouty in forum Technical - Questions
    Last Post: 11th June 2007, 08:39 AM
  5. how to fix rubbing??
    By dori_86 in forum Technical - Questions
    Last Post: 29th August 2006, 09:45 PM
