sounds like its going to be an animal...
looking forward to pics
Hey People
This is my new KE70 after the last shell has been written off....
My mate was driving when we hit a cliff with the passenger rear quater. The hit was hard enough to bend both chassis rails at the back and you can see the grab between the drives side rear door and quarter are smaller.
So the new shell will have all the AJPS suspension I had in the old car.
Plans are as follows...
Two tone paint (white roof light lime green bottom)
Full roll cage (main hoop, cross over bars, side intursion, harness mounts etc)
15x8 -9 challengers on the front
15x10 -26 challengers on the back
Bolt on fares all round (something around 50mm wider)
Spirit wing
AJPS front lip
Rose jointed 4 link and pan hard rod
Rose jointed caster rods
Some sort of fixed bucket seat (sparco or alike)
The all the other suspension bits from my other shell
-AJPS 8kg coil overs
-Rose jointed LCA (15mm-35mm over track)
-White line 24mm sway bar (front)
-AJPS rear 6kg springs
-Traction brackets
-White line 18mm sway bar (rear)
-JDM Front 86 brakes
-T18 welded 4.1:1 T Series
Then the new motor will be thrown in....
A 3SGE WITH 20V SILVER TOP QUADS
Most probably something like a mircotech running it.
So stay tuned as work should be happening pretty quickly...
Pics in a few mintues
bass_2000_au_au@hotmail.com says:
they see me drivin....a 30....neons blaring....#####s lookin dirty....look at my dirty 30
Back of the new shell
Dirty old 4K
Seats and dash (mint uncracked blue dash with what i think is blood on the seats)
Blue door trims (The only ke70 ive ever had that has had the chrome strip on the inside of the drivers door)
No more 4k
No more heater a/c or fan
What the old KE70 looked like
I want my ke looking just like your old one
keep up the good work
Hey all
Just a quick update. I ordered some cusco tension rods (caster arms) through AJPS and they should be here in the next month or so....
My 3SGE and quads will be at my place hopefully tomorrow. As soon as it arrives I will update with some pics.
Also picked my the 3Y bellhousing to suit the 3SGE.
Ones all that has arrived work will be slowed down a lot as I need to find a new place to live before anymore work happens
Cheers Craig
Will have pics up in a few minutes of the new motor and quads
Silver top quad throttles on 3SGE manifold...
Another of the throttles
Top of motor (with dizzy cap on it lol)
Dizzy set up (has been moved to the front of the exhaust cam gear for RWD and Stock ECU)
Exturnal oil drain exhuast side (Like the 100kw 4AGE on but it's aftermarket as the 3S's are know for oil pooling in the head)
Exturnal oil drain back of head
finally.
how do you adjust the timing with that setup? I can't see any way that it would move
I really dont know. I've only had the motor for about 2hours and havent had a good look at it yet... I wont be using that setup though. I will be going with an aftermarket ECU with coil on top of plug most probably or along those lines.
