Will go have another check later
any visual differences?
mine look exact, same size, same bolts, same everything.
Wondering what the difference is between adm ae86 calipers and jdm ae86 calipers?
Reason is I have adm shit on my ke70 atm, and have what is supposed to be a pair of jdm calipers in the shed. Though they look to be exact same, all the numbers on them are the same too except one, I think on adm its 71, on 'jdm' its 81.
These supposed jdm calipers are on jdm vented rotors and dont seem to fit properly, grinding away the outer edge of the rotor.
Any help is apprteciated...
Cheers, Ben.
The JDM calipers are the same size as the ADM ones except they can hold a thicker rotor as far as I'm aware (so they should be thicker?). An ADM caliper with slightly worn down pads should be able to fit over a vented rotor.
My car had a drum ADM rear and we are converting it to JDM disc rear, would somebody mind putting up a photo showing a JDM rear with wheel removed and caliper and rotor in place?
"There is only Bathurst, the rest is just waiting." Allan Moffat.
edit: i have nothing to offer sorry haha.
i took a heap if you want more from different angles.
That's terrific Jip, thanks, just what I needed.![]()
