just a few custom parts like supercharger mounts,alternator mount(?), and then your cooler piping, the block itself will bolt up the same as any 4age
know i have a 4agze :2thumbs: how much harder is it to put it in ,is it eazyer to do a 4age conversion then a 4agze so eazy or harder
well im going a 4AGZE conversion at the end of july and have been told there are alot more mods that have to be dun
The SC mount needs a chop up to fit the RWD engine mount, the intake into the throttle needs to turned or moded, the out let on the SC to intercooler needs to made up. Then theres the cooling system that needs to be done. Wiring in the ecu and mounting the coil packs everything else. Also you need a 16v 4AGE or 20V 4AGE flywheel (GZE flywheel is 230mm in diameter and doesnt fit in the T50 bellhousing)
and you will need to fit a VN full pump
all up its going to cost me $5900 giv and take
the 4age conversion is alot more strate forwood and cost less
its all together i have a 4ac in my car now all motor is together its a front wheel drive motor 4agze
tiedau what did you pay for motor
well im paying $1500 for the motor thats on top of the $5900
here is a site that will tell you what has to be dun
thank heaps i mite swap it to my cusin for a 4age thanks fellas :2thumbs:
TieDau: I think you may have a slightly incorrect understanding. A ZE is not really much harder than a GE. Both require a bit of rooting around like wiring, getting the cooling pipes all going to the right spots, etc (unless you get an originally RWD 4AGE, in which case it is only wiring).
The only things harder for ZE are:
Mod SC mount - 5 mins max with a grinder.
Flip intake pipe and make spacer - an hour or two to make the spacer
IC mounting and piping - Not that hard (15 mins with zipties and gaffer tape or a couple of evenings to do it properly)
For the power gain, and ease of further increases I think you'd be mad not to go ZE. However that is just my opinion. Whether it really is worth it is a personal decision.
