Page 5 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 41 to 50 of 156
Thread: 4AGTE Build Specs
  1. #41
    AE71 Rolla
    Also off topic but do you have your speedo hooked up to your 57?
  2. #42
    May 2010
    Jason
    a sigma push bike speedo goes up to 300km/hr u just glue the pick up inside front rim and the other part goes around the shock does max speed/laptime/distance $35
  3. #43
    Senior Member ToySprinta's Avatar
    Steve
    Padstow
    yup, its 20% out though
  4. #44
    AE71 Rolla
    You're a mad cnut hahaha. i am definatley doing that. :2thumbs: :2thumbs: :2thumbs: :2thumbs: :2thumbs: :2thumbs: :2thumbs: :2thumbs: :2thumbs: How big is the screen though??? Stupid question but is it legal?
    20% aint too much though. just do 50 in a 60 zone on your speedo
  5. #45
    Oldschool Member
    Mar 2006
    Anyone used a W56 gearbox out of a 2wd Hilux? If so does what bellhousing did you use as it looks like a different pattern to W58?
  6. #46
    W56 and 58 'should' have the same bolt pattern, all w5* should in fact. Correct me if I'm wrong!!
  7. #47
    Will be very soon ill let you know
  8. #48
    Oldschool Member
    Mar 2006
    I am pretty sure the W50 has a different bolt pattern. Want to run the W56 as I have one I got for free so will save on cost. But have not seen any one with a custom bellhousing bolted up to it.
  9. #49
    Steve
    Padstow
    should be common knowledge, but if you build ure engine with ARP studs, make sure you grind down the front exhaust side one, otherwise it and ure CAS get cosy
  10. #50
    Aaron
    Vic
    Ballarat
    Any bellhousing that bolt to a w55 w57 w58 will bolt to the W56. But I believe the input shafts are longer on the W56, 190mm compared to the 160mm of the W55 W57 W58, so they won't fit.
