Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 36
Thread: Does YOUR corolla shoot flames?
    Veteran driftism's Avatar
    Andrew
    Watsoia
    Default Does YOUR corolla shoot flames?
    friend sent me this link via aus300zx via boostcrewziing
    Hi, i've installed a flame thrower kit on my car and alot of people been asking me how do i do it, so im gonna write up about it.
    The car is a Toyota Corolla AE92 sedan running 4A-F (carby) Automatic without cat exhaust.
    Item need:
    *on/off switch
    *Coil
    *Circuit box (the thing that make the coil spark)
    *spark plug
    *spark plug wire
    *15mm bolt
    *Relay (optional)
    *Fuse holder
    *5 amp Fuse
    I DO NOT live in Aus so dont ask me where i get the stuff from
    This is the diagram on how to set it up. I choose to set up with relay so i can be sure the coil is getting the power it need and it also seems to be alot safer than running it trough the switch.
    Dont forget to disconnect the battery before you start.
    I run most of the wiring and install most of the part in the trunk because its easy to get to. And its also right above the exhaust.
    lucky this car already have a hole on the side in the trunk so i can just run the spark plug wire trough it.
    Yes i know my car is rusting....
    when you get the spark plug wire under the car make sure its not touching the exhaust pipe.
    This part you have to drill a hole in the exhaust pipe as close as you can to the tip and weld on the 15mm bolt so you can screw in the spark plug.
    install the switch where you can reach it easily just incase something happen.
    this is how it looks in my trunk when everything is done.
    check your wiring properly before you turn it on. when its on there should be spark at the spark plug all the time
    Now enjoy!
    i will not responsible if something happen so watch out what you are doing.
    sorry my english is not that good.
    http://www.youtube.com/watch?v=iiZrie89Ed8 - vid of it doing the thing it does
    Site Supporter Javal's Avatar
    Josho
    I'm going to go ahead and 'lolfail' this.
    Senior Member dave2221's Avatar
    would be cool for night runs on the shifts
    but no.
    edit* real flames are cool tho.....
    Senior Member sotiros86's Avatar
    Andrew
    Wollongong
    Remember kids, you don't have a 10 second car like the fast and furious cars unless you can spit flames.
    Not only does it make your car more hecktic than having 12 bajilion blow off valves, but you can also toast marshmallows whenever you want
    Andrew
    Watsoia
    i think its mad!!!
    its just for shits and giggles, i dont think the bloke think he's cooler for it.
    breno
    but lol.
    im going to do this on my mazda thats sitting around for funnys
    breno
    but lol.
    Senior Member quadeyquade's Avatar
    Quade
    i should do this with my seca sx
    Senior Member all torque's Avatar
    Certainly "real" flames are cooler. But this is still good. Anything that shoots fire is good.
    lol I like how elaborate and neat it all is.
    Quote Originally Posted by slydar View Post
    The real question is - if you can not even make an attempt to write a question in the manner in which someone is likely going to want to answer it... do you really think you're capable of doing an engine conversion?
    Senior Member awang's Avatar
    Zul
    Brunei
    Stone City
    Brunei
    yeah look ok
  1. 20v Shooting flames out of intake
    By Jacobxxx in forum Technical - Questions
    Last Post: 16th October 2012, 04:05 PM
  2. F1 Engine on the dyno - Flames and all
    By Matt in forum Youtube Chan
    Last Post: 8th October 2012, 09:05 PM
  3. Learn to shoot
    By sideeeways in forum Offtopic Discussions
    Last Post: 21st January 2008, 10:21 PM
  4. 4age-popping excessive flames and fluttering
    By james86 in forum Technical - Questions
    Last Post: 27th September 2007, 09:46 AM
  5. greek hachi spitting flames
    By Ade_Mc in forum Toyotas in the Media
    Last Post: 22nd June 2007, 07:48 PM
