Results 1 to 10 of 15
Thread: Left Handed(Reverse) drill bit
    Member Jase86's Avatar
    Jason
    Melb. S.E.
    Default Left Handed(Reverse) drill bit
    I need a reverse or left handed drill bit to remove a snapped flywheel bolt - havent had any luck finding any in my local tool shops, any suggestions as to where I can buy one or anyone local to me willing to loan me one? I'm in Melb S.E. - Moorabbin/Clayton area.
    Dusty
    Lynbrook
    tried using easy out's?, or is there any thread at all showing?
    Jason
    Melb. S.E.
    Nah no thread showing. I have some easy-outs but still need to drill the bolt to use them. I reckon it will come out easy enough just trying to drill it if I use a reverse drill bit.
    Dusty
    Lynbrook
    should just be drilling it with a standard bit then using the easy out to get it out
    Trev
    Queensland
    Redbank Plains
    A left hand drill bit is a good option tho as they can grab causing the bolt/stud to come out, Have you tried Blackwoods?
    Jason
    Melb. S.E.
    Will give them a try - cheers.
    Senior Member KE70's Avatar
    Alek
    Lalor
    Won't a left threaded drill bit just loosen your chuck when you drill?
    Trev
    Queensland
    Redbank Plains
    Quote Originally Posted by KE70 View Post
    No, It wont come undone.
    Senior Member 45aken's Avatar
    Marko
    just buy a kinchrome screw remover set, should cost about $20.
    drill into the bolt, choose the right size and it'll come out.
    Saved my ass many o times.
    blackwoods will have them (not kinchrome) without a doubt.
    Scammer, DO NOT BUY FROM ME!
    try jaycar they make a kit to fix this problem i think
  1. drill bit sharpener
    By ae71 in forum Tool Talk
    Last Post: 22nd June 2013, 05:36 PM
  2. Anyone have a 9mm drill bit, and a 10x1.25 tap?
    By Gunner in forum Sydney & NSW Events and Discussion
    Last Post: 9th July 2012, 01:20 PM
  3. Replies: 1
    Last Post: 7th December 2011, 11:12 PM
  4. WTB:ae86 parts wanted bonnet left headlights left gaurd
    By crillman in forum Cars or Parts Wanted
    Last Post: 27th March 2008, 03:15 PM
  5. WTB brisbane: left front guard, left mirror
    By bahnugget in forum Cars or Parts Wanted
    Last Post: 27th March 2007, 09:41 AM
