that mechanics name is steve from a-spec lol :2thumbs:
Hay fellas after getting a quote to insure my 86 ive decided to part out the parts i aquired for my 4age 70 project.
Rwd 4age pulled from running wrecked ae82 engine didnt miss a beat, has had the following done, 4ac flex plate, spigot bearing, new toyota fly bolts when bolted back up, cooling converted to rwd, new toyota intake gaskets, jap bigport rwd mannifold wiht tvis and tb, std ae82 oil cooler, ignightor, fwd ae82 loom and ecu (uncut) t50 brought as good condition but cant confirm.
$1100
AE86 engine crossmember $70
Modded t18 peddle box to fit 70 $35
Ae86 4ac/4age solid engine mounts and rubber ones $30
AE86 gearbox x member $25
solid ADM 86 clutch line $20
t18 solid clutch line $15
s/s Surge Tank (new) with fittings $140
vl hiflow fuel pumps $40 each
Locked Tseries with sway bar mounts drifted on by leighton fine (work was done by his mechanic)$400
ae86 S series with full tailshalft $170
ae86 rack $100
std ae86 rad good con $30
twin core rad ( not sure what model it came from) $40
ae86 t50 was in exallent condition before car was burnt out seems fine thoe. $230
also have a set of gay hi offset rims good for sliders 15x6.5 (no rubber)$200
Intercooler large onsided cooler approx 500x 300x 80 $200
also wreacking 2 ke70's one flat front and another slant pm with parts ure after........ and the ae82 parts car.
PICS ON REQUEST.
Shipping can be arranged via aus post or large items to any tasfraight depo
Items are located in Tas, Hobart
Contact Via: Post or Pm
hey bro keen for the pedal box and the x member would you post to qld pm me
makin osme money on that t-series?
what side dose the t-18 clutchline go to? drivers or passenger side?
hahahahaha
actually wak, your making squillions on that diff of mine you kent
drifted on by crab.... hahaha.... adds slig points surely!
hahahahahah thats it dude
t18 is on drivers same as jdm one aparently
thanks for that info delazy!!
yes will ship.
AE82 fwd box?
PM sent regarding engine mounts
