Results 1 to 10 of 13
Thread: DIY Longboard
    Senior Member shinny's Avatar
    Liam
    Default DIY Longboard
    make your own Longboard
    all you need:
    big sheet of paper
    plywood +10mm
    powertools
    vanish
    trucks and wheels
    to start off with you need to sketch the shape of the board that you want and cut it out
    my design was about 10inches wide x 3foot 3inches long (254mm x 1030mm)
    next up pin it to you plywood and trace around the design
    then get a jigsaw and cut the design out of the plywood
    sand the edges and flats to smooth out any bumps or rough edges
    fill in any holes with putty and sand it back
    varnish both sides (or paint choice is yours) to make it look nicer and keep water out
    draw a line down the centre of the board and mark the holes where you want your trucks to go and drill them out with 5mm drill bit
    next up get some griptape, skateshops will have it
    lay it on the board making sure there are no bubbles and mark the edges
    using a razor blade carefully cut the excess grip tape away
    fit the trucks and ride the bastard
    on a final note - you might have to try different spots for the trucks to find where it feels right and suggest use 10mm or thicker ply 8mm gets a bit too flexible
    Member buzzin's Avatar
    JESSE
    SCARBOROUGH
    AUSTRALIA
    haha thats mad, might follow this.
    how thick is the ply ?
    Senior Member Vizz's Avatar
    Adam
    Biloela
    Good to see another DIY longboarder
    heres mine:
    1983 Sprinter making progress
    Liam
    ^^thats awesome
    its only about 8mm thick 6ply after a fair bit of sanding
    it feels pretty flexible
    but hey as far as i see it it's only a first attempt
    Adam
    Biloela
    I think it will be the goods
    Mine was a fair bit longer so to make sure it wouldnt snap on me I glued two 10mm sheets of ply together lol wood and glue came from bunnings for about $20 if i remember rightly.
    Veteran driftke70's Avatar
    Ryan
    Buderim
    nothing a layer of glass cant fix
    wheelfriends.wordpress.com
    Quote Originally Posted by shinny View Post
    all you need:
    big sheet of paper
    plywood
    powertools
    vanish
    trucks and wheels
    I cant seem to find my vanish, its dissapeared or something.
    Liam
    ^^ to be honest my vanish has a habit of disappearing on me too,
    luckily i had some varnish which was a good substitute
    Veteran shift_rook's Avatar
    SE Burbs
    fuckin sweet, i'm makin one on sunday, good to use my old board, anyone want a $150 flip skate deck for like $80, structurally great, few scratches where some fuck head borrowed it and board slid on it
    stefan
    vic
    eastern suburbs
    geez thats old school and awsome
    exact same style of thing my dad did in the 70's (surfy/hippy which is quite lol )
  1. diy airbox
    By pogi in forum Technical - Questions
    Last Post: 14th September 2009, 07:38 PM
  2. Coilover DIY
    By drftr86 in forum Technical - Articles
    Last Post: 20th July 2008, 05:00 PM
  3. Coil-over DIY
    By Dish in forum Toyotas in the Media
    Last Post: 12th November 2007, 04:16 PM
