Results 1 to 10 of 17
Thread: WELSH PLUGS ---- how to replace etc
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default WELSH PLUGS ---- how to replace etc
    So before I chuck my 20v in the 86 I thought it may be a wise idea to replace the welsh plugs....
    (unless the silvertop comes with brass plugs standard?)
    I don't think this is the case so anyways... where can I get replacements? like are they a fairly universal item (was looking at some at supercheap the other day and they seemed to be the same size)
    next how/what is the best/easiest method of removing them, and what type of sealer do I use when putting the new ones in?
    Cheers ladz
    Niz
    BENT MECHANIX - Garage 20:
    Senior Member Marco's Avatar
    Marcus
    Jindalee
    best way to replace them. is to hammer a screw driver through it and lever it out. We use a sealer called stag at work. im sure there is something better out there. some one on this site will probablt know the name. and no they aren't really a universal fit. maybe call rapeco with an engine number?
    Jonathan
    They are universal, in that they are sized to a metric size in mm. So for example, if the hole is 32mm, you go to any car shop and ask for a 32mm plug.
    I think I have used silicon on them, but almost any sealant should do as they should come close to sealing on their own.
  • #4
    Senior Member KE70's Avatar
    Alek
    Lalor
    Remember to use a socket the same size to bash them back in.
  • #5
    Niz
    South~Slide Briz
    cool, cheers for the tips guys..
  • #6
    Gone
    Joel
    Picton
    just for the dummies whats the purpose of the welsh plug?
  • #7
    Niz
    South~Slide Briz
    Not too sure on their exact purpose, but I do know that if shit coolant (ie:water) has been used over time or they have been sitting for some time without coolant to prevent oxygen contact then they have a tendency to corrode from the inside out.....
    Also.... If I were to drill a hole in them for leverage rather than bash a screwdriver through them ( a little less brutal) would the metal shavings from drilling be an issue, or would these flush out when a hose is put through the coolant passages? (before a rad is hooked up)
  • #8
    Alex
    Wagga Wagga
    To get mine out, using a screwdriver and hammer, tapped the outside lip on one side and it in turn made the opposite side pivot out. then just pull it out. Did the first one with the bashing a screwdriver through it but the other way seemed to work easier.
    (if you understand my shit description)
  • #9
    Niz
    South~Slide Briz
    yeah that makes perfect sense dude..
  • #10
    Niz
    South~Slide Briz
    ok so I just removed one of the welsh plugs from the block (almost lost it inside the block lol)
    It has no sign of corrosion and looks fine.... is it worthwhile taking out and replacing the rest of them as I am assuming that they would all be the same...... correct?
  • Page 1 of 2 1 2 LastLast
    1. 4ac welsh plugs
      By joshyouwahh in forum Technical - Questions
      Last Post: 26th July 2010, 10:39 PM
    2. Can anyone replace my dizzy O-ring?
      By AE092 in forum Melbourne & Vic Events and Discussion
      Last Post: 7th February 2010, 08:44 PM
    3. Starter Motor - When to replace?
      By li21 in forum Technical - Questions
      Last Post: 1st June 2008, 09:32 PM
    4. What to replace with.
      By hugh in forum Technical - Questions
      Last Post: 6th March 2008, 03:14 PM
    5. Where to buy injector plugs and important sensor plugs
      By HYPNTK in forum General Topics (No Technical Questions)
      Last Post: 14th March 2007, 02:39 PM
