Results 1 to 10 of 20
Thread: Hopefully laying offset questions to rest for good
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    Default Hopefully laying offset questions to rest for good
    alot of guys are kind of confused about the whole offset thing with positive and negative offset. hopefully this can help guys out from now on
    The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
    ZERO OFFSET
    The hub mounting surface is even with the centerline of the wheel.
    POSITIVE OFFSET
    The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
    NEGATIVE OFFSET
    The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
    MEASURING OFFSET
    To determine the offset, the wheel must be measured accurately using the following steps:
    1) measure the overall rim width of the wheel.
    2) measure the backspace, which is the measurement from the hub surface contact area to the outside of the inner rim.
    3) divide the overall rim width by 2 which gives you the center line.
    4) subtract the center line (overall rim width divided by 2) from the backspace.
    5) a negative answer means the wheel has a negative offset and a positive answer means the wheel has a positive offset
    FTP.
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    This should help millions, gw champ .
    Oversized 86
    http://www.1010tires.com/WheelOffsetCalculator.asp
    add that to the top post also...
    Veteran slide86's Avatar
    Huw
    Hills
    also remember, dont measure from the outside of the lip to lip
    its from the bead sealing edge to edge. people get caught out on that too
    john
    nsw
    liverpool
    a couple of dumb question with i think easy answers .
    1. how do ppl know by just looking at the wheels in a picture what offset the wheel are ?
    2. how do you know what offset you need for you car >? all good to know how to work out the offset the wheel has .. but how do i apply it to actual fitting them on or getting it flushed with the guard without scraping anything in the inner gurads .
    Huw
    Hills
    buy the wheels then get the car to fit around them....maximum win
    Senior Member adam's Avatar
    Adam
    Measuring from lip to lip will work fine when trying to find offsets. It's when you're trying to determine the wheel width that you should measure from where tyre would bead.
    Adam
    Quote Originally Posted by redsprinter View Post
    Some wheels come in certain widths and offsets. You can usually tell which ones they are comparing to guard clearance. It's when you have camber it gets a little tricky. Camber does a lot!
    Senior Member Chairs with flares's Avatar
    Jeff
    East...
    +1
    J.
    Senior Member 4.5AG's Avatar
    Vener
    NT
    Lyons
  1. WTB: 16 x 8 good offset wheels.
    By kyle unwin in forum Cars or Parts Wanted
    Last Post: 18th April 2012, 11:42 AM
  2. Set of superlites 15x8 0 offset w/ good rubbers
    By -luke- in forum Car Parts For Sale
    Last Post: 15th April 2011, 02:30 PM
  3. WTB: 4x114.3 with good offset for my KE
    By 20inch in forum Cars or Parts Wanted
    Last Post: 29th April 2010, 04:27 PM
  4. full set of wantanabies 13/6 good offset
    By DRFTAE71 in forum Car Parts For Sale
    Last Post: 20th June 2009, 05:41 PM
  5. Good offset
    By Dish in forum Technical - Questions
    Last Post: 29th October 2007, 10:54 AM
