i was trying to find information on this.
was trolling the forums for a while and putting pieces of info together.
this would have saved a few hrs of my life
yeh buy and try its the best way
mitve been covered but, is offset measured in mm?
bought a hatchi from daylesford..
...spiders...everywhere...
Correct
X-posted from the technical questions forum since it's relavent...
J.
for this reason, it is sometimes possible to get a higher profile stretch under a guard than a lower, also, brings more significance into your ride height. But if you talking differences between 6 and 7 your missing the point.
wheelfriends.wordpress.com
how can i tell what offset i will get if i reverse my meshies? they are 15x7 +25
My guess from rough calculations would give you around a -50 offset.
This is assuming the wheel is 3pc and the where the center bolts up to the barrel/lip is the same 'offset' as the hub mounting face.
I could be wrong... very wrong...
J.
Reverse them then use them as anal plugs in the Mardi Gra.
Just an example; same principles apply to calculations or comparisons between an 8J and 9J wheel.
Meshies?
As a plug?
FAIL!
You'd clearly need SSR Mk1's or something similar with a flat face and no spokes...
J.
