Results 1 to 10 of 16
Thread: do i need an engineers or vass certificate?
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    Default do i need an engineers or vass certificate?
    i have just purchased my first ae,
    a GTV levin sprinter running a 20valve with quad throttles.
    the previous owner had the car registered with a EFI 16valve 4A-GE up in QLD. Now that the car has a 20v and is down in melbourne. Do i need an engineers or vass certificate or not because i know that when an engine is replaced, (if its the same engine) then a certificate isn't needed.
    any info will be much appreciated.
    Veteran slydar's Avatar
    Dimitri
    yes you do. the authorities to not consider a 20v 4age to be the same engine as a 16v.
    Filip
    Jozzaville
    alrite cheers.
    hopefully wont have to much trouble getting one
    it wont be fun.......and it will be about 800 bucks....
    Dimitri
    qld ftw its $80.
    Senior Member all torque's Avatar
    If the 20v had been engineered in QLD, would you still need to get a new certificate for Melbourne?
    Quote Originally Posted by slydar View Post
    The real question is - if you can not even make an attempt to write a question in the manner in which someone is likely going to want to answer it... do you really think you're capable of doing an engine conversion?
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    800 ? id just say i changed engine stuff that 800 can be saved for some phat rims
    Filip
    Jozzaville
    qld ftw its $80.
    im going up to QLD, if i just get it engineered there will the certificate count for VIC?
    and how long does it take for a mechanic to analyze whether it is "engineered".
    also, does anyone know any mechanics that i can take it to seeing as its only 80 bux, save some coin and use it on some watanabes
    Veteran Rice86's Avatar
    Richard
    Liverpool
    trip to qld and back is still cheaper then 800 bucks
    getting done on the way there and back, priceless =]
    dose
    Filip
    Jozzaville
    Quote Originally Posted by Rice86 View Post
    lolz nahh im picking up some dirtbikes in a van and will chuck the AE on a trailer, so thats why i wana know if it will work
  1. Engineers Certificate in NSW, Past experiences/ recommendations
    By GOT-20V in forum General Topics (No Technical Questions)
    Last Post: 12th March 2011, 09:07 AM
  2. Engineers Certificate
    By sotiros86 in forum General Topics (No Technical Questions)
    Last Post: 7th January 2008, 11:16 AM
  3. engineers certificate?
    By Gilly in forum Technical - Questions
    Last Post: 1st May 2006, 11:25 PM
