Results 1 to 8 of 8
Thread: instrument cluster woes
    Senior Member patience's Avatar
    Iain
    Alderley
    Default instrument cluster woes
    Hi guys
    Tachometer on the dash decided to stop working a few weeks ago.
    Along with fuel meter and and temp.
    Pulled the cluster out today and all seemed to be fine, plugged it back in properly and didn't work.
    Speedometer is working and so are all the lights.
    coincidentally this stopped working around the same time as I took my airbox off and put velocity stacks on, though I highly doubt this has anything to do with the problem.
    Anyone think they know what's wrong?
    Cheers, Iain
    Jonathan
    I know in older cars such as KE55, the fuel and temp gauges were both powered off a small voltage regulator chip, in the cluster. And when that chip blew, both gauges stopped of course. Not sure if that helps. If could be a main power wire going to the dash somewhere.
    Sutherland
    this happen in my 86,
    fuel, temp and oil pressure didn't work.
    ended up being an earth wire in the engine bay right hand side that was the cause.
    as soon as this earth wire was touching metal it all worked.
    hope that helps
    Iain
    Alderley
    Thanks heaps guys
    DR86TY, where was this earth wire located on the right hand side?
    Will have a look tomorrow and let you know how I go with it
    Iain
    Alderley
    Still no luck with this
    Forgot to mention other big factor, the fans/switches in the middle stopped working all together as well.
    getting a bit hectik with foggy windows recently
    may contact an auto sparky to see if he has an idea if I can't figure it out in a few days
    Senior Member Anthony's Avatar
    Anthony
    id say your reverse switch wires have melted on the exh. check the 'gauge' fuse behind drivers kick panel.
    Iain
    Alderley
    thanks mate, will do right now.
    Iain
    Alderley
    so when can I drop this six pack of bundy round with your name on it... heh
  1. C.O.P's and auto Sportive Instrument Cluster
    By DR86FT in forum Car Parts For Sale
    Last Post: 29th February 2012, 12:37 PM
  2. AE86 instrument cluster surround
    By 4.5AG in forum Cars or Parts Wanted
    Last Post: 9th October 2010, 06:22 PM
  3. wtb. KOUKI instrument cluster
    By baka_ae86 in forum Cars or Parts Wanted
    Last Post: 21st June 2007, 02:56 AM
  4. wtb jdm instrument cluster
    By slippry in forum Cars or Parts Wanted
    Last Post: 27th April 2007, 04:39 PM
  5. Removing Instrument Cluster
    By syco86 in forum Technical - Questions
    Last Post: 15th May 2006, 11:39 PM
