Higher is better. Like 1.5" gap between tire ang guard.
If you're going to run more caster, you also need to run more camber as the castor will wind on positive camber the more you tunr the wheel. To keep the front contact patch "constant" or as close to it as you can, you need to dcrease castor lots and deal with the wheel not returning/centering as fast yourself.
