I'm VERYY interested SHOTGUN!!!!!
Gday,
For sale is a Clutch pedal assembly with Master cylinder, clutch lines and slave cylinder. Will also include the brake pedal assembly. WIll include brake booster and brake master cylinder for additional cost.
Cost is $100 for clutch stuff. Additional $70 for brake master and booster with no leaks.
Ideal for manual conversion in AE71 and KE70
Can post but clutch lines will get damaged so pick up is the go.
In melbourne.
Thanks,
Jez
86 pedal does work. but does not bolt in. that being said I think the end result is a better set up as it does leave you with more room for your left foot.
86 brake pedal not required for clutch conversion. and I can't see why it would help or be an advantage.
78's
Reason it's a help or advantage is it's there for someone to buy for whatever the reason they need to mate.
Like a lot of things that get sold.
I have it, I don't want it, somone may want it. I sell it, they are then happy and so am I.
Thanks.
All clutch stuff sold pending payment.
Thanks
