will pay 100 for just the turbo oil lines water lines and actuator???
I have a T25 off a ca18det, very minimal shaft play and I was told it didnt blow any smoke but I can't garentee this because I have never used it, after $120 for this one
brand new 280x300x76 front mount intercooler, has never been used or fitted or anything, just took it out of the box for a look, A1 condition, has 3" outlets, good for a 4agte or 4agze, after $120
custom made fmic pipeing for a tubo set up on a corolla with a 4k-c, it's all press bent and has been made to fit a 300x600 fmic with 3" outlets, has a hole to mount bov, make that 4k go.......... after $40
all prices are very negotiable so make an offer
I will psot everything but at your expense
all items are located in Hobart Tasmania
cheers james
no oil or water lines
you can have it for 110 +postage
Consider posting the pipework to Brisbane? (Postcode 4108) Come with clamps and silicone? What size is it all? Where bouts does it run?
yes I will post at your expense, no clamps or silicon hoses etc, it's just the main steele pipeing, I think it's all in 2 1/4" and it comes from the top fo the carby, goes down towards the washer bottle, down through the gaurd and curves back around to the front, goes throught the fmic and then back up through the inner gaurd and then goes down to 2" just before going into the turbo, it's really good quality work and has the bov mounted between the carby and the washer bottle area,
I'm negotiable on the price
BUMP
any one intrested, need it gone, wiil take $100 for the turbo and $115 for the fmic
