Results 1 to 7 of 7
Thread: hydraulic throw out bearing
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    Default hydraulic throw out bearing
    i have one of these set ups it came with my w5x box when i got it just wanted to no if nayone has one and pro's and con's of a set up like this
    please discuss
    Nathan
    Lilydale
    these are handy if your using an auto bellhousing, ie. you can make/buy an adaptor plate from an auto 1uz bellhousing to W5* and use this throwout setup, leaving no mucking around with cutting holes, drilling and tapping etc.
    other than that i know shit all about em! i do like the idea tho!
    Veteran driftke70's Avatar
    Ryan
    Buderim
    set up one with a friend in a jzx100, with a r154, pretty nifty little thing, took a little shimmage to get it sweet and had to make a spacer on a lathe but worked out pretty awesome, awesome pedal feel too. Id do it if i had the time and inclination and money.
    wheelfriends.wordpress.com
    underwood
    qld
    jimboomba
    sweet i understand the pedal feel but does it make it heaps harder to push the pedal
    Ryan
    Buderim
    easier
    Veteran Beau's Avatar
    Beau
    id run one of these if i could be bothered. Just cause you lose the salve and the fork system. Makes things easier and lighter. dont have to worry about heat effecting the slave or anything like that
    Ryan
    Buderim
    easy bleed sort of too, and you get a better push on the clutch plate.
  1. pic of altezza throw out bearing
    By Celica RA45 in forum Technical - Questions
    Last Post: 26th May 2011, 05:54 PM
  2. throw out bearing carriers
    By Gilly in forum Technical - Questions
    Last Post: 17th August 2008, 08:21 AM
  3. URGENT, throw out bearing question
    By Brendo in forum Technical - Questions
    Last Post: 28th March 2007, 04:05 PM
  4. throw out bearing part number
    By hahaboy in forum Technical - Questions
    Last Post: 11th January 2007, 12:04 AM
  5. Throw out bearing - the thing that goes under it
    By Nikkojoe in forum General Topics (No Technical Questions)
    Last Post: 21st July 2006, 03:19 PM
