Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 32
Thread: Modified NA 4AGE 16V
  1. #21
    Aust.
    sorry to highjack, but what power figures could one expect from some 264 cams, ITB's and an ECU? for reference, on a jdm 16v.
  • #22
    Senior Member lo_rolla's Avatar
    Was that aimed at me? If so, yes. Lachlan, he's the manager of 999 Automotive and knows his hachi's (has had something like 30 in the last 8 years)
  • #23
    Senior Member shelldrake's Avatar
    meridan motorsport in moorabin(melbourne) sell fully built race 4age 20v's stroked with a 7a crank, billet rods, forged custom pistons, worked head(ported, cams, etc), 50 mm throttle bodies and some other goodies for 5.5k ready to go. They have been race proven and produce 205-225 rwhp, reliably.
  • #24
    Senior Member shinny's Avatar
    <div class='quotetop'>QUOTE
    yeah I think under 8.3 mm lift you can get away with, but over 8.0mm you need h/duty springs
    can anyone correct this??[/b]
    ????,..you said under 8.3mm lift should be ok..but over 8.0mm you need support?? did I miss anything?
    [/b][/quote]
    hehe yeah sorry I mean't anything over 8.3mm-ish you need a shim kit...?
    and between 8.0 - 8.3 all you should need is stronger valve springs
    and under 8mm you should be able to get away with stock valve springs
    I'm not 100% sure of these figures but I think they are close,
    it would be nice if someone could back me up or correct me....
  • #25
    meridan motorsport in moorabin(melbourne) sell fully built race 4age 20v's stroked with a 7a crank, billet rods, forged custom pistons, worked head(ported, cams, etc), 50 mm throttle bodies and some other goodies for 5.5k ready to go. They have been race proven and produce 205-225 rwhp, reliably.[/b]
    Can they be on the road???
  • #26
    Senior Member awang's Avatar
    Brunei
    <div class='quotemain'>yeah I think under 8.3 mm lift you can get away with, but over 8.0mm you need h/duty springs
    [/b][/quote]
    [/b][/quote]
    i believe the maximum lift is 9.0mm, above than that, inner shim kit are required, even if the lift is at 8.5mm u can still use the standard lifter
  • #27
    it would be nice if someone could back me up or correct me....[/b]
    [/b]
    ooOh sweet yeah i wasn't 100% sure as i said,
    cheers for the corection
  • #28
    Senior Member Medwin_3sGTE_AE86's Avatar
    Don't forget a bigger final drive ratio (at least 4.6:1) to suit your new engine. They make a massive difference. With cams and cam gears, upto around 290 deg cams are still very driveable, i wouldn't go any less. 260ish cams are for people who doesnt want to change ecu. Also, fast NA motors are more sensitive about gear ratios.
    I personally think a hard tuned NA 86 is more fun than a turboed one. gl with your build.
  • #29
    Dec 2006
    Do a 7AGE with 20v quads. Torque AND power.
    Some forged high comp pistons, stronger rods, cams, quads, adaptronic. Done [/b]
    give away my plan much lol.
  • #30
    haado gei
    Talking
    [/b][/quote]
    sounds pretty good value
  • Page 3 of 4 FirstFirst 1 2 3 4 LastLast
    1. sprint 500 na 16v tune anyone have one?
      By toyotakraze in forum Technical - Questions
      Last Post: 27th December 2012, 04:35 PM
    2. NA Mild tuned 16v or 20v
      By obey wan boenny in forum Cars or Parts Wanted
      Last Post: 6th May 2012, 07:15 PM
    3. NA built 16v
      By damo46 in forum Cars or Parts Wanted
      Last Post: 24th May 2008, 04:57 AM
    4. EOI: Toda enhanced motor - NA 16V
      By 70XIN in forum Car Parts For Sale
      Last Post: 4th December 2007, 12:43 PM
    5. na na na na na na na na na BATLEB!
      By snake in forum Offtopic Discussions
      Last Post: 8th November 2007, 10:05 PM
