OMG THAT WAS GOLD!!!! BI...... BI SEXUAL......GOES BOTH WAYS
do i need to spell it out anymore??
I remember a Slick50 infomercial on American TV in 1994 (before they got sued, they had to admit Teflon had no known benifts in oil.) They had a complete V8 motor running on a stand, with Slick50 added. They drained the oil out of it while it was running, then removed the sump. The audience was shocked. Then just to add something else, they got a firetruck to come with a hose and blast the bare crank and rods still spinning in the motor. But thinking about it now, I bet the water was introduced at the perfect time. All tested and timed to perfection by engineers, especially if the water was aimed at the oil pickup.
here is a personal testemony... johnny i dont mean to be rude but it seems your a very big skeptic...look, this guy looks like he knows what he is talking about.. he mentions gains in HP, torque and alot negative HP.. drivetrain drag.
check it out.
Its easy to look like you know what your talking about - especially if your receiving financial motivation!
Here is some info I found from a document on the net:
Make of it what you will. I have come across a few references to the use of these chlorinated paraffins and the detrimental effects of their use over time on the net. Best not to believe what people making money from it have to say.
These guys all use a similar machine:
Megapower:
DuraLube:
RoilGold:
etc...
as well as Wynns which I have seen in person.
Americans reminiscing about the crap infomercials they grew up with:
good info man,, thanks for that, i guess their is always stuff like this laying around the web
Anyone tried adding snake oil in the engines? lol
If you want quality oil, buy royal purple etc, don't add an additive to crappy standard oil.
i use penrite SIN 5 in my 4a and Sin 15 in the hilux
I knew it was too good to be true....
BENT MECHANIX - Garage 20:
i use royal purple in my 4a just getting the thickness wright im gonna be using a thinner stuff in my new motor as for less kms on it but as for an additive may use royal from royal purple its good stuff
the dyno pull to 300rwkw
