Results 1 to 6 of 6
Thread: 4age 100kw small port manny problem
    Stefan
    Parkinson
    my car isn't idling well all the holes are blocked off on the manny I need to know what goes where the rocker cover to vacume is fine what goes where
    Jonathan
    There should be one small vacuum hose going from a filter/connetor thing on the manifold to the MAP sensor.
    yee you will find that hose that goes to the map sensor next to the hose that goes from your rocker covers to your inlet
    Stefan
    Parkinson
    any pics please
    Dec 2006
    hope that helps you.
    Stefan
    Parkinson
    I have a vacume at front of manny and a open hole at back of manny do I need to block off the front hole?
    currently it has the front vacume going on to the map sensor hole and rocker cover is going into oil ctach can
  1. [vic] small port 100kw 4age engine.
    By dan.91 in forum Car Parts For Sale
    Last Post: 1st August 2011, 08:59 AM
  2. 100kw small port 4age
    By Snowman in forum Cars or Parts Wanted
    Last Post: 15th September 2007, 10:22 PM
  3. 3 inch zorst on a 4age 100kw small port
    By slippry in forum Technical - Questions
    Last Post: 3rd September 2007, 06:36 PM
  4. jdm 4age 100kw small port motor.
    By E V A N in forum Car Parts For Sale
    Last Post: 19th April 2007, 02:20 PM
