Find a ae82 corolla with a 4ac. They have the item you are after.
Can you use the electronic dizzy out of a tercel motor a 3AC or is there another engine you get them from.
Is it easy to install do you just put it in and plug the wires up.
Fucks me, Have never owned a 4ac ae82.
I think you need the coil aswell as i THINK they have a ignitor ?
Ok ill get the parts then work it out.
My shitty 4AC has electronic dizzy. No idea what it's off (came with the car) but it has the exact same wires out as a normal points dizzy as far as I can tell. Just electronics doing the work inside, not mechanical points.
mechanical points ignition ftl
no mechanical part has ever given me as many hed farx as the points, they are poo
i have a electric dizzy for my 4ac too, havnt looked at it yet but yes i believe you need the coil to match it. also pay attention when you pull it off, the ae82 i got mine from didn't have a coil and the wires are slightly different from a points dizzy.
