Results 1 to 10 of 16
Thread: GZE head... and cam question
    Dusty
    Lynbrook
    hey,
    just pulled my head off today.... well attempted to, took all the head bolts etc... off and then bracket that holds the supercharger onto the block but still the head doesn't budge at all... I'm trying to pull the head off with the supercharger etc still attached anyone have any ideas on what is still holding it on?? all head bolts are out so thats not it.
    Next question i have is, the whole big port cams has been thrown around a bit, do these run fine, stock cam gears etc? any different to set up? i don't think they are just want to confirm.
    P.S hen was right the head bolts and even the rocker cover gasket are exactly the same as GE ones....
    the end
    thanks in advance
    hey,
    the end
    thanks in advance[/b]
    youd be lucky to get the whole sc setup off with the head its by far easier to just take it off first. you have to take the outer part of the manifold off to acees other bolts anyway im sure it is mounted to the block behind the outer manifold. not sure on ge bigport cams but im running na smallprt cams in my gte worked fine!!
    Dusty
    Lynbrook
    youd be lucky to get the whole sc setup off with the head its by far easier to just take it off first. you have to take the outer part of the manifold off to acees other bolts anyway im sure it is mounted to the block behind the outer manifold. not sure on ge bigport cams but im running na smallprt cams in my gte worked fine!![/b]
    got it off.... turns out i wasn't putting my back into it its all off with the supercharger and everything, so now i jsut need the cam questions answered, and wondering if there will be too much of a loss at the bottom end cause of overlap and boost leaking out
    Next question i have is, the whole big port cams has been thrown around a bit, do these run fine, stock cam gears etc? any different to set up? i don't think they are just want to confirmi dont understand what that means??
    Dusty
    Lynbrook
    Next question i have is, the whole big port cams has been thrown around a bit, do these run fine, stock cam gears etc? any different to set up? i don't think they are just want to confirmi dont understand what that means??[/b]
    people have said you can put bigport cams on a gze and its an "upgrade" just wondering if this is true? and will i have overlap problems e.g losing heaps of bottom end etc???
    I've never done the cam swap myself, however Wing (DODGY86) spoke to me about it once. Sounded like it was a straight bolt in affair.
    Bear in mind that the cam changeover wasn't the same as bigport -> smallport, it happened earlier. This means you can get a bigport motor with the "smallport" cams. Also we are talking about a change from 232deg/7.1mm to 240deg/7.56mm (from the top of my head, easy to confirm/deny though). It's not going to set the world on fire. I'd suggest you won't even notice the difference.
    stefan
    vic
    eastern suburbs
    im pretty sure its all bolt in. the big port cams are 242deg arent they? which is probably a little bit of an upgrade i spose. big port heads are cheap why not jus put one of them on?
    Easy way to check, take off the cam covers, then measure lobe lift with verniers.
    stefan
    vic
    eastern suburbs
    hmmm thats in interesting pic. ive got small port cam gears on my engine but its a big port :blink:
    Senior Member ToySprinta's Avatar
    Steve
    Wentworthville
    Ran big port cams on my smallport GZE, helped it breath a bit better higher up.
  1. gze cam/crank angle sensor
    By armc89 in forum Cars or Parts Wanted
    Last Post: 19th November 2011, 09:22 AM
  2. 4AGE/GZE Cam angle sensor/CAS
    By Harreh in forum Car Parts For Sale
    Last Post: 29th September 2011, 12:16 PM
  3. what is this off with a gze bigport head
    By xwfalcon in forum Technical - Questions
    Last Post: 26th May 2008, 07:12 PM
  4. 4A-GZE Pollished Cam Covers
    By stretch in forum Car Parts For Sale
    Last Post: 20th February 2008, 05:25 PM
