Results 1 to 8 of 8
Thread: mystery 20v sensor?
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default mystery 20v sensor?
    Just trying to confirm what the sensor is on the intake side of the block on my ST.20v.... (I'm guessing knock or temp) it has a 19mm (I think, maybe bigger) hex head and is located in between 2 of the welsh plugs...
    Need to know as mine is fucked and need to know what to ask for before I throw up a wanted post..
    Niz.................................
    BENT MECHANIX - Garage 20:
    Veteran slydar's Avatar
    Dimitri
    knock.
    dont need it unless youre going stock management.
    78's
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    i htougth only black tops had knock
    i'm probably wrong tho
  • #4
    Moderator Frak's Avatar
    Jamie
    ST has knock sensor as well
    Hachiroku since 1994
  • #5
    Niz
    South~Slide Briz
    schweet, one less thing I need to source..
    cheers...
    although I will be running a razor back ecu, which runs off factory sensors and settings to an extent... But I take it that its still not essential..
  • #6
    i run a razorback on my 20v, no need to most of the stuff under the intake, including the knock sensor.
    Drift skills? i thought buying an import was all you needed? well..... im screwed
    Banzai parts garage
    Action tyres southport
  • #7
    Niz
    South~Slide Briz
    cool, cheers mate....
  • #8
    Scammer, DO NOT BUY FROM ME!
    yeh mine has that to but its not connected to anything, i run a microtec
    sonny.
  • Similar Threads
    1. 20v water temp sensor
      By fergie in forum Technical - Questions
      Last Post: 22nd February 2011, 01:49 AM
    2. Regarding 20v Speed Sensor
      By mikare in forum Technical - Questions
      Last Post: 23rd July 2010, 11:14 PM
    3. 20v map sensor with plug
      By dr1ft-pig in forum Car Parts For Sale
      Last Post: 8th July 2007, 11:54 PM
