Results 11 to 20 of 24
Thread: TPS Adjustment
  1. #11
    Veteran Nikkojoe's Avatar
    Tom
    <div class='quotetop'>QUOTE (4AGE - 86 @ Feb 12 2008, 05:56 PM) </div>It wont die when you rev. Ive driven my car without tps for testing purposes and my mate has not run his tps since it failed about 6months ago. Without tps it wont go into idle loop.
    These were both bigport ge's and my gze running an ae101 ecu/loom works fine without tps.
  2. #12
    Jul 2009
    Adam
    Gold Coast
    yeh i was pulling my hair out for a few weeks wondering why my 4age was running like shit after i put the head back on after it had some work. found that same article, set of feeler gauges and multimeter and had the thing running sweet in half an hour. so if ur kanga hopping cruising slowly or when u get on or off the throttle then check to see if tps is positioned correctly
  3. #13
    Nov 2006
    can someone explain what you have done once you finish the test? how do you work out how much to adjust it by? and which direction?
  4. #14
    parrot
    The explanation is.....download the manual from the tech docs and do what it says.
    I think Toyota know how to do it.
  5. #15
    Tom
    Just unplug and leave the tps there
  6. #16
    Dusty
    Lynbrook
    <div class='quotetop'>QUOTE (4agteketo @ Feb 17 2008, 10:08 PM) </div>why would you do that though?? if you can run it run it
  7. #17
    Veteran driftism's Avatar
    Andrew
    Watsoia
    <div class='quotetop'>QUOTE (parrot @ Feb 17 2008, 02:32 PM) </div>Where is this, i was trying to find it and i couldn't
    really need to have a look as well, so if you could point me in the right direction it would be great!
  8. #18
    Andrew
    Watsoia
    oh, and i disconnected my tps today just to see how it runs....
    it runs, but idles at 2k and when you press the throttle it dies for a moment and then revs up again. not really ideal if you ask me...
  9. #19
    parrot
    When you come into tech articles, look at the pinned items at the top of the page. Click on
    'Find your body manuals and wiring diagrams here'
    Scroll down the thread a little way and you will find the diagnosis manual, electrical wiring diagram books etc that I have scanned and had posted on aeu86.org The diagnosismanual is invaluable and includes a very nice simplified engine wiring diagram as well as how to adjust and diagnosis TCCS faults
    I would just post the link, but hopefully this will help other people in future find it themselves. I'm not having a go at you! I never look at the pinned items either.
  10. #20
    Andrew
    Watsoia
    I thought that was it, but i didn't want to download it on dialup and then discover that it was the wrong thing!
    Cheers mate.
  1. axle adjustment
    By Loaf in forum Technical - Questions
    Last Post: 18th March 2009, 10:01 AM
  2. 20v TPS adjustment
    By 4AGE - 86 in forum Technical - Questions
    Last Post: 21st February 2008, 12:22 AM
