Cant toyoland help you out chapl?
I'm sure rick should be able to help...?
hey
need the TPS 'male' plug to fit my AE101 throttle bodies..
need it asap!!!
anybody?
all toyota tps plugs should be the same,
just take it off and take it to the wreckers
nope
20v ones have 4 wires
16v have 3 wires
Toyota genuine maybe?
Have you tried some other late model Toyota's. I've heard that late model Camry plugs are interchangeable, not sure if its off the TPS though. Bigport TPS and a Nissan CAS plugs are the same, go figure.
If you don't have any luck you should be able to find another toyota TPS with the same stud spacing.
Its the other way around
16v = 4 wires
20v = 3 wires
hmmmmmmmmm
im looking at the tps on the throttle bodie now and there are 4 connections?
the 4th wire is just a throttle closed signal.
