The more negative the wheel offset is, the further the rim edge will sit away from the hub, so further out. A more postive offset will make the wheel sit further 'in' the guard. tyre clearance should only be a problem on the inside chassis rail if the rims are very positive, in your case they arent so your only concern will be rubbing on the outer guard.
