Page 9 of 9 FirstFirst 1 2 3 4 5 6 7 8 9
Results 81 to 89 of 89
Thread: TYRE SIZES
  1. #81
    Oldschool Member
    Mar 2008
    <div class='quotetop'>QUOTE (steroidchickens @ Mar 28 2008, 06:31 AM) </div>you missed the actual point there....
    posing stretch or usable stretch.....
  2. #82
    Rob
    Moorabbin
    ^ says he who had 195/50 on 10s
  3. #83
    Veteran biggo's Avatar
    Nick
    Noosa
    hahaha pwned
    poser for sure.
    SHICHI- theres plenty of decent tyres out there in 185/60, and quite a few good ones. plus its not posing if it jusssst fits your guards
  4. #84
    Veteran Konakid's Avatar
    Henry
    Eastern
    <div class='quotetop'>QUOTE (federal @ Mar 28 2008, 02:21 AM) </div>No, a 195/60 too big for e7 guards and will leave minimal room for lowering, also giving scrubbing issues when running castor.
    185/60 is perfect for almost any 14 unless its a 10J
  5. #85
    Paul
    West
    thanks heaps guys ill get shit free ones and see how the fit
    the 14x8 just clears the strut so i think a bit of stretch is needed
    [attachment=24188:CIMG0463_800x600.JPG]
  6. #86
    Oldschool Member
    Mar 2008
    ok...yes i ran a 195/50/15 on a 10, due to lack of room and needing the car on the road....
    195/60 Will fit in the guards of a ke, 185/60 will also cause problems when winding out the castor so your comment is mute....
    a 14x8 0 offset with a 185/60 will also cause problems with lowering unless you plan on flaring your guards....which lets face it, you would want to anyway, so seeing as the guards should be flared then 195/60 is the perfect size for someone who wants "grip"....
    but you wouldn't know that henry, seeing you've only ever had 7's in positive offset....
  7. #87
    Nick
    Noosa
    since when was JHS ever so informative?
    another piont - 185/60/14 - cheaper
  8. #88
    Oldschool Member
    Mar 2008
    JHS is always informative, however 90% of the time this is via PM
  9. #89
    Oldschool Member
    Aug 2007
    i run 205/50 on my 15x7s.
    side walls are pretty much vertical.
    benefit gives me alot more cornering grip for street driving. heaps of improvement
  1. Tyre sizes for 15 x 7 ?
    By Trindawg in forum Technical - Questions
    Last Post: 4th August 2007, 11:16 AM
  2. Rim Sizes + Tyre Profiles
    By driftke70 in forum Technical - Questions
    Last Post: 25th January 2006, 12:48 AM
