should be fine wont really do anything changing your pump tho cause the standard reg is set to a standard fuel pressure so thats all it will flow
Hi Guys,
Just wondering if i need to upgrade the stock BT20V fuel pressure regulator if I run a 255LPH fuel pump which is rated at 35-100psi. Or would the stock regulator have sufficient flow? The pump is an ebay cheapie so who knows if it even flows 255LPH... but considering it was 20 bux more than the generic OEM... I figured, why not?
Thanks,
Ves
Sweet thanks for that.
