misfire as in backfire? or a miss. I dont understand how it could stall after it warms up if it runs when cold.
to check, do you have cold start pluged in?
if the injectors are to big, that would mean its running rich yair? dose it blow smoke?
have you comp tested?
are you running advanced timing? either way the comp may be made to run it or not?
what ecu exactly?
