Cut your exhaust.
Cut your exhaust.
Yeah i will need to for mallala as its way too long and they dont like it.
Its a drift car brooooo...
sweat as car . dont cut pipes they look the peice
Hey dudes,
Not much of an update as i have been slack but i have sorta gotten off my ass to do something i this junk box lol
So i put all the intercooler piping all together and did the clamps up, put the front end on and dummyed the new chrome bar that is straight and complete. Test fitted the 15x8s on the front cos i was bored.
Needs to be lower but i will do that later, thats the coilovers maxed out lol
all is left is the ecu wiring and shit and fuel pump! then broom
should be getting my adaptronic ecu and bits this week! BUT i need the loom plugs, these are what i need to get her going!:
- Air temp sensor plug$
- 4x injector plugs $
- rear water outlets at the back of the head needed?
- thermostat plug needed? there is already a temp sensor at the top hose
- coil pack plugs 1 each pack (2)
- coilpack igniter plugs, has 2 plugs
- altenator plug
- crank angle sensor plug
- knock sensor plug
- throttle position sensor plug
IF anyone could help then that would be great!!!!!!!1
cheers guys,
Davey
flog the plugs from upullit, if u cant find any 4ages then there are a few 3sge's there and they are pretty similar.
Get ur fuel set up done the other night?
alrighty might be going friday as thats my day off!
didnt do the fuel system cos im doin night shift so i sleep in the day lol
come help me ian ?
possible if u help me bleed my clutch
and you can have a look through all my wiring left overs
Hey kids,
Got my adaptronic ecu today! yay there is alot of wires haha got the $1000 box with 2m loom and 3bar map sensor.
Got my radiator in and the fill up tank (from a discovery) 4 core, shouldnt have any heating problems!
Got the alenator mount finished, looks strange but it works.
Had to mod my clutch pedal as it was hitting the steering column, so a little bending made that all sweet, this is a T18 pedal box i am using.
