Results 1 to 10 of 16
Thread: removing rack ends... htf?
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default removing rack ends... htf?
    anyone got any helpful suggestions on how to remove rack ends from the AE86 steering rack without a SST...?
    Niz
    BENT MECHANIX - Garage 20:
    Jonathan
    Fold the metal lock washers over.
    Use a very large shifter.
    Or use large multigrips.
    Or get one of Grandpas witworth spanners and grind it to shape, your very own SST to keep.
    Niz
    South~Slide Briz
    awesome I'll give it a crack, cheers Jonny
    User fantapants's Avatar
    Pat
    yeah just beat the big adjustable with a bigger hammer
    06/07/2011
    Pat
    actually i lie... i mangled mine with a multis then hammer
    06/07/2011
    Senior Member Stain's Avatar
    Derek
    Far North
    I took em off just yesterday. I ended up taking the handle off my jack and slipping it over the end of the spanner for max torque/leverage and it came off easy.
    Aaron
    or you could use a 30mm or 27mm spanner depending on the brand of rack ends they are.
    Niz
    South~Slide Briz
    yeh I got them off without much hassle...
    Just have to take the actual rack out now......... easiest way to do this?
    Can you get the lock washers for the tie rods at supercheap etc?
    Jonathan
    You normaly have to buy the rack ends to get the washers. I have new washers here if you need them.
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    Washers can be bought from Toyota, cost about $2
  1. XT130's with P/S rack, longer rack ends?
    By Jimmee1990 in forum Technical - Questions
    Last Post: 6th December 2011, 07:31 PM
  2. [melb] rack ends and rack bushes
    By shakes in forum Car Parts For Sale
    Last Post: 10th May 2010, 09:28 PM
  3. Replies: 0
    Last Post: 5th March 2010, 06:59 PM
  4. Replies: 1
    Last Post: 3rd November 2009, 07:52 PM
  5. rack ends
    By sprintrphile in forum Cars or Parts Wanted
    Last Post: 29th August 2008, 02:09 PM
