Results 1 to 10 of 18
Thread: Diff center for grip driving.
    Default Diff center for grip driving.
    Hey fellas,
    What is main choice grip drivers go with diff center i heard that it is usually 1.5way? Is that correct?
    Whats the best diff center for grip?
    Jack
    Sunnybank
    Brisbane, Queensland, Australia, Australia
    It doesn't make that much difference in lap times aye... If you are a good racer and can put down consistent fast laps, there won't be any much wheel spin involved. The car will feel very different though. When i first wacked in my cusco 2way i was expecting it to give me massive advantage... it just wasn't there, sure the car felt much nicer to slide around on and off power... but laptimes are pretty much the same.
    The biggest difference i felt between 1.5 and 2 way was when you car is already sliding, and you lift off the gas, with 2 way...car keeps sliding... with 1.5 way.. the car will try to get grip again...stopping the slide.
    hope that helps...~!
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I tottaly disagree, maybe you didnt have any sudden tight corners but I kept on lighting up my inside wheel around the last 90 degree bend before the main straight on the winton race track
    Jack
    Sunnybank
    I know what you mean, in very tight corners esp you've just clipped the curb with your inner rear. Last corner at Queensland raceway is just like that, not to mention its just before the main straight... where differences should show up big time. But it doesn't.
    In normal racing situations (not riding on curbs) with high grip tyres, even tight corners can be handled nicely with open diff... you just have to use the throttle much more smoothly.
    Just try it and time yourself... you'll be surprised how little difference it makes.
    By no means am i saying open is faster or better.. but for track racing in a sprinter with semis... the difference is FA.
    F1 cars of 70's/80's (forgot exact time period) tested and used open diffs because it was more efficient (LSD saps power)... and sometimes exceeded the traction benefits.
    Jack
    Sunnybank
    Oh... forgot something really important... SETUP!!! Open diff setup should have keeping the inside rear contact patch intact as priority... ie. soft rear swaybars...
    Endeavour Hills
    interesting and I hear you. WHen I was at Winton I for example would follow someone and then lose some speed getting off the throttle to get traction back. I was also thinking that what if it was possible that someone could take a more agressive line on the inside and get the power down where I could not. But I am very unsure if such a situation like that be actually possible or if it really made as big a difference as you suggest. I wouldn't be suprised if in the end it didn't that much.
    oh and I have found that too soft in the rear end causes heaps of problems too.
    Senior Member Intense's Avatar
    Aaron
    The biggest difference I noticed is that with an lsd the car bites into corners. With an open wheeling diff you can tell exactly when it's going to loose traction but there's nothing you can do about it except to back off and then get on the power again when it's become all civilized. With an lsd it'll bite in and you can keep feeding it power, too much and it'll step out. It almost feels as though the car is turning in a lot harder with an lsd. Hard to explain more of a feeling if anything but you'll know what I'm talking about the moment you jump into an lsd equiped car
    Jack
    Sunnybank
    If i have the choice... of course i'll choose a LSD car... especially on a AE86.
    All i'm saying is don't laugh off a open diff car because they're just as fast...
    Wheelspin (in racing) is not something you feel then back off and then on your way again... You anticipate it coming and you should control your throttle so that it never becomes an issue...
    Having said that, if the track was wet/dirty/bumpy/really tight... basically where acceleration traction is a big issue... LSD definately makes a big difference...
    Veteran driftke70's Avatar
    Ryan
    Buderim
    i can put up with open until you start throwing stuff like off camber roads and what not, like my hilux holds a bit more corner speed than my rolla did in its last livery, thats open and commercial tyres, compared to 2 way and higher end street tyres, two different cars i know, but you can be much more aggressive in places with an open diff, get some real floaty entries and direction changes that scrub off very little speed.
    wheelfriends.wordpress.com
    Jack
    Sunnybank
    So... to answer your question AE86R... If you can afford a LSD, just go the 2 way. Dont bother with the 1.5... its not going to give you any more speed. 2 way is more fun anyways. If you can't afford a LSD, just stay with open diff for the street, you're car will be just as quick in most situations. If you're track only and you're pov, then weld up the diff like dave has suggested... save you heaps of money..~!!
  1. s-series diff center
    By buster86 in forum Car Parts For Sale
    Last Post: 5th June 2009, 12:21 AM
  2. Diff center for grip driving.
    By AE86R in forum Technical - Questions
    Last Post: 7th April 2009, 12:49 AM
  3. what is this (diff center)
    By Eddy in forum Technical - Questions
    Last Post: 25th March 2009, 09:49 PM
  4. Diff Center
    By -Leigh- in forum General Topics (No Technical Questions)
    Last Post: 22nd July 2006, 08:55 PM
  5. What Diff Center Is This ????
    By RolandGTV85 in forum General Topics (No Technical Questions)
    Last Post: 30th May 2006, 07:44 PM
