Results 1 to 10 of 12
Thread: SE QLD: AE71 Corolla
    Daniel
    GC Hinterland
    Default SE QLD: AE71 Corolla - SOLD
    Hi Everyone selling my brown corolla
    pics:
    I have only had it for a month but decided to get a new car (2006) because it was taking too much time from my white ke70. Here are some details
    - 1984 AE71 Corolla 5 speed
    - Excellent 4AC doesnt blow smoke or use oil and water
    - Weber carb, mild cam and 2 1/4 exhaust
    - Near new SAAS wheel and boss kit
    - 14 inch mags with good tyres
    - Excellent condition T50 and quiet borg diff (yes its true!)
    Since getting it I have done a few things
    - Flushed cooling system, purchased new thermostat and Radiator cap
    - Installed New re-cored AE86 radiator
    - Installed a Craig Davis thermo and controller
    - Installing a new KE70 steering column and reassembled the dash to factory standard. (rt141 was in for unknown reason...)
    - Fitted 4AC electric distributor, static timing set to 9btdc but would benefit with some advancing
    - Disassembled and serviced Weber 32/36. New power valve and Needle and seat installed Idle system fixed, new fuel filter
    - Brakes disassembled, cleaned, adjusted and then bled. One rear brake cylinder replaced.
    - Tacho Dash installed and 3 electrical issues sorted.
    The body is in good condition and has minor rust. The interior is in good condition also
    for RWC in my opinion it needs two things
    1. Dash/parker light fuse blows need to find short (eliminated rear lights)
    2. Wheel alignment.
    The car has rego until July but selling as is where is.
    looking for 1700 ono
    The car is located on Mt Tamborine
    PM or reply here. I will give out my number in PM only.
    Daniel.
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    Looks good champ, GL with the sale.
    Daniel
    GC Hinterland
    cheers mate
  • #4
    Member crazy nanna's Avatar
    Hurb
    Wynnum
    hey mate
    can you send me your phone number?
    thanks
    IMMORTAL IMAGES
    tattooing & body piercing
    home of the dori oni tattoo
  • #5
    Daniel
    GC Hinterland
    pm sent.
  • #6
    Daniel
    GC Hinterland
    I forgot to mention that it has new plugs, penrite oil and oil filter
    I also have done a REVS check and the car/engine is unencumbered.
    If i sort the electrical issue i will get a safety certificate and sell the car with rego until july.
  • #7
    Daniel
    GC Hinterland
    bump.
  • #8
    Jason
    Queensland
    Maroochydore
    hey man would you take 1500 for it?
  • #9
    Daniel
    GC Hinterland
    pm sent
  • #10
    hey mate if you hold it for a few weeks ill be interested
  • Page 1 of 2 1 2 LastLast
    1. T50 shifter wanted in SE Qld
      By Group A in forum Cars or Parts Wanted
      Last Post: 21st August 2009, 12:49 PM
    2. Wrecking T18 and Corolla - SE Qld
      By moberman in forum Car Parts For Sale
      Last Post: 4th June 2007, 10:52 PM
