Page 1 of 11 1 2 3 4 5 6 7 8 9 10 ... LastLast
Results 1 to 10 of 106
Thread: Load of AE86 perfromace parts for sale
    Default Load of AE86 perfromace parts for sale ***PRICE DROP!***
    Custom AE86 side skirts (Fit very well)
    $70
    SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD
    BELOW THIS LINE
    Twin core radiator with dual thermo fans and fan controller as as new
    (easy fit to an ae86 more one bottom rad bracket)
    & Large Oil Cooler from 100 seriers landcruser
    $80 for both SOLD
    While line tail lights with garnish complete
    $230 SOLD
    4x bolt on Wheel spacers, 45mm x2 from T1 alloy, 50mm x2 from T1 alloy
    On Ebay
    17x7 Apache wheels, as new with very good secondhand tyres and wheel nuts
    On Ebay
    Sports steering wheel and super long boss kit
    $60 or $30 wheel and $60 boss kit SOLD
    Jap Door Mirrors Electric with switch
    $110 SOLD
    HKS Mushroom style aire filter with new filter
    $25 SOLD
    Carbon fiber seat (material cover extramly worn)
    $40
    4age Dizzy with cap
    $25 SOLD
    2x Racing harness (new)
    $30 pair SOLD
    Standard 8 bolt Flywheel
    $30 SOLD
    Front bar some japanese style
    $80 SOLD
    Standard ae86 rear bar
    $25 SOLD
    TRD chopped front springs 8kg
    $50 SOLD
    15in rims, multi 5 stud
    $80 SOLD
    DRFT86 Number plates (VIC)
    $350 SOLD
    Razorback ECU, fuel and timing adjustable, with had controller and cable (has internal map sensor) and manual PLUGS INTO STANDARD LOOM no wiring needed
    $480 SOLD
    Tein adjustable camber plates with pillow ball joints x2
    $250 (1 person interested) SOLD
    Full Alloy front strut brace
    $80 (1 person interested) SOLD
    $120 SOLD (1 person interested)
    Oil catch can D1 Racing
    $40 (SOLD)
    LH seat rails for fiberglass or carbon fiber seats
    $40 SOLD
    Fiber glass seats 1 yellow (as new just dusty)
    $60 SOLD
    Long Motor (7 rib block, big port head, 285 deg cams with 9.1 lift, heavy duty valve springs, TRD 0.5 metal head gasket T3 adj cam gears, full reco, rings bearings gaskets the lot, port and polished, takes a external oil cooler) has run for about 1 hour since rebuild. With dizzy new cam new rotor, with thermostate setup for rwd
    $1350 SOLD
    Custom 4-2-1 Extractors with jzz80 supra cat and 2.5 in exhaus with dump pipe
    $350 (SOLD)
    Quad throttle setup, Silver top throttles, T3 bigport inlet manifold, Vacumm tank with guage and vaccum spliter, Throttle cable, T1 Alloy trumpets and Unifilter socks) Complete setup
    $900 SOLD
    TRD Front and rear springs 8kg front, 6kg rear, low (as new)
    $300 SOLD
    TRD Green short stock Shocks used. Rear adjustable
    $250 SOLD
    TRD 4.1 lsd Disc brake Diff, very tight lsd with new project mu pads and 2lts of LSD oil (Complete with calipers new cross drilled discs and handbrake cables) Comes with braided brake lines
    $1500 SOLD
    RX7 S5 front brake upgrade for AE86. 2x new rx7 dba slotted and crossdrilled discs, 2x rx7 4 spot alloy calipers, new bendix ultimate pads, T1 alloy centric ring and caliper adapter plates and hubs.
    $600 SOLD
    AE86 RCA 40mm x2
    $80 (SOLD)
    Whiteline X Series (27mm) Front sway bar as new with bushes
    $150[B] SOLD
    Whiteline heavy duty (??mm) rear sway bar as new with bushes
    $100 SOLD
    Whiteline adjustable panhard rod as new
    $110 SOLD
    T-50 Japanese box with shifter
    $360 SOLD
    T-50 Aussie Box with shifter
    $260 SOLD
    $70 SOLD
    AE86 EFI Fuel tank some dints
    $160 SOLD
    Chrome Moly Light weight flywheel
    $250 SOLD
    Front + rear braided brake lines, new, never had fluid in them
    $65 SOLD
    N/Denso Dual reduction start motor of a 4AGZE (Very good condition)
    $80 SOLD
    Jap LH + RH Park Lights (1 has crack bottom plastic lip but lens is good see pic)
    $180 SOLD
    $40 pair SOLD
    Fiber glass seats, 1 yellow (as new just dusty)
    $60 each SOLD
    Carbon fiber seat (material cover missing)
    $60 (1 only) SOLD
    Roll Cage
    $160 SOLD
    2x Racing harness
    $60 pair SOLD
    AE86 shell with std diff and suspension (Has full body kit, sun roof, ductail wing, in highfill, custom bonnet. Custom Grey interior, engine bay and door jams painted in 2pac ppg bright red, comes with 2ltrs of paint (2 person Interested)
    $2100 SOLD
    rgeorgiou@dodo.com.au
    0421630326
    Located in northern suburbs of melbourne (local pickup prefered)
    Regards
    Rick
    Daniel
    GC Hinterland
    hi mate in regards to this
    RX7 S5 front back upgrade for AE86. 2x new dba slotted and crossdrilled discs, 2x alloy calipers, new bendix ultimate pads, T1 alloy centric ring and caliper adapter plates and hubs.
    $600
    is that front or rear im a bit confused... if front which discs does it use?
    Quote Originally Posted by munki View Post
    $600
    ops front only
    it uses rx7 discs cant put 13in wheels on the car any more, 14 just clear the caliper
    Josh
    Mid North Coast
    how much 4 the shell?
    Nic
    Mt Evelyn
    any pics of camber plates?
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    if your negotiable on the diff, im interested
    Senior Member LEVIN86's Avatar
    Nam
    Westside
    pm sent
    Senior Member shichi~'s Avatar
    Ethan
    North Suburbs
    Razorback ECU, fuel and timing adjustable, with had controller and cable (has internal map sensor) and manual and full wirinng loom (engine and dash) and ae82 twincam instrument cluster
    $500
    $80
    im interested in both mate but who tunes Razorback ECUs in VIC
    Josh
    Mid North Coast
    hey mate u got a pm!
    Quote Originally Posted by shichi~ View Post
    $500
    $80
    its a knock of motec, so anyone really, razorback has a website i beileve
    ill get some pic hold on the camera is charging
  1. Replies: 17
    Last Post: 14th November 2011, 04:43 AM
  2. WTB LOAD OF PARTS
    By silver styler in forum Cars or Parts Wanted
    Last Post: 25th December 2006, 03:44 PM
Tags for this Thread
