Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: snapped 4age flywheel bolts
    Member sirsprinter's Avatar
    Zac
    South Australia
    Angle Vale
    Default snapped 4age flywheel bolts
    A combination of an uncalibrated tension wrench and/or, weak bolts and carelessness, has left me with a broken flywheel bolt for my smallport. We have managed to remove the broken bolt.
    Now what can i do? does anyone have any laying around? Particularly Adelaide? ASAP>?
    Should i ask for genuine toyota, or can i match the bolts at a motor traders. etc provioded they are high tensile steel and exact dimensions? Wreckers even?
    furthermore, should i replace just the one, or a whole set of 8, seeing as one broke, i dont want to take a risk with any others...if so, will a wrecker be fine or should i try source brand new?
    thanks guys
    Veteran slydar's Avatar
    Dimitri
    ive torqued my flywheel bolts to spec once. the one time i did. pow. shnapped em.
    every other time ive used 2nd hand ones and just done them up TIGHT, with loctite (a debate in itself) and its been all swoit. for a while there we didnt use loctite, and ive actually heard one car i worked on the flywheel came loose
    you will be able to use a 4ac bolt instead of ge. the head is bigger, but it will fit between the 4age bolts, so you can use upto 4 4ac bolts with 4 4age bolts.
    Zac
    South Australia
    Angle Vale
    i saw that the bolts were larger... i didnt bother taking them out... so you say i can use a 4ac bolt?
    seriously!
    theres no issues with balancement?
    and my mate said NO loctite... he reccomended a rattle gun swears by it....
    Zac
    South Australia
    Angle Vale
    should i use 4x 4ac bolts and 4x 4ag bolts so its balanced>?>?
    if this is possible? anyone else heard of doing this?
    Mick
    Penrith
    I wouldn't recommend a rattle gun, maybe on its lowest setting, but best to use a breaker bar (or torque wrench) and some loctite.
    Zac
    South Australia
    Angle Vale
    why loctite? he swears and curses at people who do... can i have an explanation? just wana know and can anyone confirm the 4ac/4ag bolt usage?
    Zac
    South Australia
    Angle Vale
    just one? or should i even it out, 4 and 4 for even balancing?
    Dimitri
    do either, not gonna make a difference.
    i say use loctite. they do come out with some type of thread lock solution from factory on them.
    you can use a rattle gun if youre familiar with it.
    also.. im not talking from like, doing it once or twice..
    ive fitted about 20/30 4age clutches.
    Jonathan
    New 4A-GE flywheel bolts from Toyota. Sometimes in stock, and affordable. Not something you want to take a chance with. I have bought new ones before, easy. $3 each.
    90105-10076
    Unless you are a mechanic and have done these up with a torque wrench a number of times and have a very good feel, then you need to borrow a torque wrench and do them up to spec.
    Zac
    South Australia
    Angle Vale
    [QUOTE=Jonny Rochester;4283]
    90105-10076
    QUOTE]
    is this the part number for smallport? as i swear i read somewhere bigport use 6 stud pattern... if it matters... just dont want to be stuffed around
    cheers johnny
  1. ARP flywheel bolts
    By Gabe in forum Technical - Questions
    Last Post: 13th December 2011, 11:37 PM
  2. Flywheel bolts
    By trikzlane in forum Technical - Questions
    Last Post: 26th July 2011, 08:03 PM
  3. 4age parts, rwd waterpump setup, flywheel bolts + more
    By DearmanKE in forum Cars or Parts Wanted
    Last Post: 2nd September 2010, 10:34 PM
  4. WTB 4age flywheel bolts (NEW)
    By no fame in forum Cars or Parts Wanted
    Last Post: 9th February 2010, 09:44 PM
  5. WTB- Needed 4age flywheel bolts ASAP
    By Sprinter_Seth in forum Cars or Parts Wanted
    Last Post: 12th December 2007, 12:52 PM
