Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Whiteline Swaybars
    Senior Member shawn_26's Avatar
    Shawn
    Southside
    Default Whiteline Swaybars
    Iv'e got a JDM Kouki Levin coupe. Just wondering if upgrading to Whiteline front and rear swaybars is worth doing. As I think I have heard that JDM swaybars are thicker than ADM?
    If i was to upgrade to Whiteline swaybars front and rear, what sort of handling difference am I likely to get?
    Veteran shift_rook's Avatar
    SE Burbs
    everyone has varying opinion on swaybars, they're a cheap way to minimise body roll, however there are certainly better ways to minimise it
    Senior Member stylz's Avatar
    Art
    Melb
    what are you talking about? upgrading the sway bars is one of the better things to do to get rid of body roll. most people try to eliminate body roll by just going stupidly hard spring rates which i believe isnt the correct way to go about doing things
    Quote Originally Posted by stylz View Post
    exactly my thoughts...
    more anti roll control via swaybars and quality adjustable shocks and less via ridiculous spring rates and "other vehicle replacement shocks"
    rather than whiteline look into the selby range AJPS are offering...made to the same quality (due to selby having previously made whitelines for them) but custom/better sizes and to top it off a linkage system that will actually work and not cause more dramas than they are worth...
    Veteran Konakid's Avatar
    Henry
    Eastern
    Quote Originally Posted by DrifTE72 View Post
    Swaybars the the BEST way to minimise bodyroll, sure stiff springs can help but then you create other problems such as wheels losing traction as they bounce off bumps.
    From experience i dont really rate the whiteline swaybars, especially the adjustables, though the rear non adj i had seemed to be sound. Talk to Dave at AJPS about some Aussie made Selby swaybars, much better quality and custom sizes too.
    Dave
    spoken like a true internet expert!
    as state sway bars are a great upgrade
    i wish went down the swaybar route rather than the "stiff springs" route.
    though my car is stiff i can still feel the body rolling (8kg/6kg with stocko sway bars). i think i can afford to put in stiff springs with some new swaybars and get it to handle better. if only my wallet allowed it!
    it contributes to how new cars retain decent handling and still have comfort. the new mazda 3 is amazing in the handling area considering how comfy it is.
    just becarefull as if the front one is too stiff it can lead to excessive understeer, and if the rear one is too stiff it can lead to excessive oversteer.
    the thing i dont understand is why they cost so damn much, the goin price seems to be around $240 for each end. man i dont have $240 for a peice of tube!
    Member advan86's Avatar
    S.A
    S.A
    Yeah try AJPS at least they drive work on and own sprinters.I worked at motor traders and never sold one whiteline bar in the 3 yrs i was there for a AE86.Cant tell you if there good bad or otherwise tho.I have a stock rear bar and a fat K-Mac front bar and think its ok.Opinions vairy as suspension does.
    I remember ppl use to cut there bars and double up on the bars and clamps on the older rotaries and dattos.
    Hachiroku AE86 Masters Club S.A since 1998
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Quote Originally Posted by ke70dave View Post
    $240 seems fair for an upgrade like swaybars
    $240 for swaybars or $240 for some jdm washer+radiator bottles in total going by the price some people are wanting for them....
    fail on jdm bottles
    dose
    Sorry to be off topic but what is the point of buying jdm washer bottles seems like the most pointless money wasting exercise ever to me.
    On topic, id rather swaybars than excessively stiff spring rates for sure. 7.2kg/mm max id go for my fronts and 5.5kg/mm max rears.
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Quote Originally Posted by Axentrik View Post
    I run a 8/6 and my car rides fine... 10000% better than it did
    But my suspention is also a properly engineer coilover set...
    Not some mix and match parts... (which it was before)
    Also + like a BILLION for sway bar upgrade...
    My first KE thats all I did. Swaybars and cut springs... Handled quite good for haveing only cost only $500 to do...
  1. Whiteline swaybars
    Last Post: 1st November 2012, 11:03 PM
  2. Whiteline Swaybars Adjustable F&R (VIC) pick up only $350
    By shift_rook in forum Car Parts For Sale
    Last Post: 28th December 2010, 05:13 PM
  3. whiteline adjustable swaybars (vic)
    Last Post: 24th September 2010, 08:47 PM
  4. WTB: SWAYBARS - WHITELINE ETC
    By Robo86 in forum Cars or Parts Wanted
    Last Post: 7th May 2008, 04:22 PM
  5. Swaybars
    By keto in forum Cars or Parts Wanted
    Last Post: 2nd April 2008, 01:22 AM
