Results 1 to 10 of 15
Thread: Cabin fumes
    Member advan86's Avatar
    S.A
    S.A
    Default Cabin fumes
    Just wondering if anyone experiences cabin fumes as i do my eyes are burning and my clothes reek like fuel after a run,I dunno if it goes up thru the boot or somewhere else but its pretty full on.I have 3sgte injectors and a microtech so it runs a bit richer but i cant justify the pain my eyes go thru on 20 min of driving.I might try a new boot rubber if there still possible to purchase?
    Hachiroku AE86 Masters Club S.A since 1998
    User fantapants's Avatar
    Pat
    yeah im the same... i put oit down to open quads.....
    06/07/2011
    zilla
    nsw
    central coast
    If you can smell fuel that badly, I would be worried.
    You didn't say what set up you have (external surge tank or pump?). Sounds like your fuel supply system has some issues which require attention.
    fwiw I run open quads + gze injectors & have no problems with smell.
    Reeece
    Casula
    i run 2litre surge.. external lifter pump in the hatch.. It smelt bad whilst sitting there but never hurt my eyes.. Since then ive boxed it and i cant smell nothing.So il be checking for fuel leaks
    Pat
    yeah mines after a hard run.... just figured there was some throwback from the throttles getting dragged into the cabin. not much of a smell, just stinging eyes about half hour in...
    06/07/2011
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    I just put the windows down and smoke ciggies to cover the smell.
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    Quote Originally Posted by lo_rolla View Post
    Now thats teamwork, I do that to lol.
    you could always wear goggles?
    Jordan
    Sunshine Coast
    Quote Originally Posted by Axentrik View Post
    I lold at the thought of that..
    S.A
    S.A
    Yeah i have a 4agze it runs a Supra twin turbo feeding engine custom bent XR8 fule lines and a modified pick up in the tank,Swirl pot is in boot with a vl turbo pump used as a lift(In boot aswl).It runs that big 8mm red hose with the 3sgte injectors and the microtech probably a bit overkill but it never surges/Leans out ever and does not leak anywhere.When the engine was standard it was not so bad and i never had issues till i got the microtech and 3sgte injectors,Reace Can you post up a pic of your box job if possible ? Is it vented? Thanks
  1. Fumes in cabin
    By BARWICK in forum Technical - Questions
    Last Post: 23rd May 2012, 02:00 PM
  2. Sealing off the cabin from fumes/gases
    By Anticeptik in forum Technical - Questions
    Last Post: 17th November 2011, 02:04 PM
  3. hatch is loose sucks in exhuast fumes
    By Charged86 in forum Technical - Questions
    Last Post: 17th November 2007, 11:08 PM
  4. In Cabin Fuel Lines?
    By jason in forum Technical - Questions
    Last Post: 8th November 2007, 12:19 AM
  5. broken cabin light
    By fozz in forum Technical - Questions
    Last Post: 25th September 2007, 10:45 PM
