Results 1 to 10 of 58
Thread: bigport or smallport
    Senior Member .ady's Avatar
    Andy
    Footscray
    Default bigport or smallport
    hey guys, just wondering what are the pros and cons about these 2 beautiful engines. what is everybody running these days and WHY. correct me if im wrong but i think most people go for bigport 7 rib?
    EDIT: 20v silver/black tops?
    tvis conversion for small port?
    Senior Member blacktopspirit's Avatar
    Brendan
    Eastern
    I don't know why, there is nothing wrong with the small port!
    easier to get the head cleaned up, makes more power!
    bigport is only sort of better is your going to boost it (I think)
    Elite rthy's Avatar
    Leo
    Tulla
    smallport, newer, better design, etc... (not huge difference anyways)
    Senior Member shichi~'s Avatar
    Ethan
    North Suburbs
    bigport easier to install
    smallport harder to install
    7rib bigport best base motor for a tuf NA build
    gay
    n1gger land
    n1gger land
    south korea seoul
    my trueno has a smallport and mr2 has a bigport 7 rib.... im building a 7age for my mr2.... i will be using a smallport head on the 7age. after driving both, smallport is far better imho.
    Ray
    S.East Melbourne
    the intake holes on the big port are larger when you compare the sizes to the small port. I assume that this helps for more airflow if you decide to turbo it etc. I know on phil bradshaw's page he explains it in further detail as to why its better.
    the small port has a stronger block and has more power output as a stock NA.
    blue top (big port) 88kw vs. red top (small port) 100kw
    but blue tops are far more common, cheaper and apparently easier to install into an 86.
    Andy
    Footscray
    not planning to boost.On P's so NA POWER ! lols is it hard to convert tvis onto smallport? cost?
    Elite rthy's Avatar
    Leo
    Tulla
    tvis is shitty (This Version Is Shit)
    the small port is a better design which eliminates the use of tvis
    gay
    n1gger land
    n1gger land
    south korea seoul
    as Leo said... TVIS was shit, so on all the newer 4age engines after the bigport it was deleted.
    by designing a decent head (for stock applications) on the smallport, it is better than a bigport with tvis.
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    screw big and small, bring on the hybrids.
  1. Bigport or smallport?
    By dunga70 in forum Technical - Questions
    Last Post: 9th April 2010, 05:41 PM
  2. smallport head onto bigport
    By BLIPAE86 in forum Technical - Questions
    Last Post: 5th April 2010, 04:27 PM
  3. smallport bigport?
    By 86TRD in forum Technical - Questions
    Last Post: 30th July 2009, 04:00 PM
  4. Can I use my Bigport loom on a Smallport?
    By jet111 in forum Technical - Questions
    Last Post: 3rd March 2009, 07:24 PM
  5. bigport or smallport
    By Maxhag in forum Technical - Questions
    Last Post: 12th September 2007, 01:56 PM
