Page 1 of 12 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 118
Thread: Prewers AE71 Daily
    Senior Member Prewer's Avatar
    Default Prewers AE71 - 4AGE - Clean conversion
    Heres my $200 daily, now becoming more than a daily now though
    Picked up a few months ago, finally got round to getting roadworthy/rego.
    havent done much to it, got makita's all round, new wheels/tyres on front
    perfect for either a SR20 or 4AGE, not sure which path yet, its only a daily for now, see how the modyfying bug goes.
    I'm new to the RWD corolla scene, looking at lowering properly in the coming months, AE86 struts, brakes, shocks etc..
    before
    as it sits now
    And heres my other car, trying to sell, powerdyne super6, 12psi blah blah
    Veteran Konakid's Avatar
    Henry
    Eastern
    Clean car, but chuck the numberplate back in the middle!
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    how the fuck did you pick up an ae71 for 200 blings. thats awesome
    dont go the usual sr route, turbo a 4agze instead. a lot simpler than sr conversions
    joe
    joe
    Did i mention i have A/C, and it works.. haha
    Nil rego, no brakes, whining diff, covered in moss when i picked it up, took 3 hours to clean with a pressure washer. Its Auto at the moment, that wil be rectified in due course.
    Modifying bug has already bit, ripped the stereo out of the commodore, installed a few ricer guages (oil press, water temp), along with new steering boots, pads, shoes, cylinders, diff oil and pan gasket (was dead empty, damn snoozers...), points, condenser, new GT40 coil sitting out in the shed somewhere to fit also. scored a set of rims for nothing so lashed out and put some Yokohama C-Drives on em, they cost more than the purchase of the car, haha. Will do the rears when the rear tyres are fryed...
    Engine bay when i first popped the bonnet
    Degreaser and split sleeve tubing is your friend
    wires and stuff
    Rice time
    Joe
    NT
    Nightcliff
    nice
    keep that bug alive
    sounds like your into a bit of forced induction.
    i believe you should 4agze it the car.
    will be a lot more fun than the commy.
    promise
    Brad
    just swap the engines over, will make the commy abit faster also....
    Senior Member worked's Avatar
    ed
    tas
    wynyard
    joe
    silvia crossmembers bolt in with probably 2mm of elongating of holes to fit to ae/ke's x-member mounting points - ideal. then your eng mounts etc are done, only prob is changing clutch is an engine out job.
    make a gearbox crossmember and get used to the shifter sitting back further and you've got yourself a 900kg car with 150kw+
    turboing 4ags requires new exh. manifold and locating a rwd or modded fwd inlet which gets a bit tedious and hard these days, finding 4ages let alone 4agzes down in tas is woeful and ends up costing the same amount as sr/ca conversions. in the end do what you want. otherwise you'll never be happy with it.
    if you need any help with it prewer drop me a line.
    ed
    NEAR MISS
    Quote Originally Posted by worked View Post
    ed
    and you too can own an abortion on wheels
    only stiring, edds bus was already an abortion when he got it, i hear its actually becoming respectable with all the work edds putting in
    Cool man. looks clean and cheap. 4age ftw
    ed
    tas
    wynyard
    Quote Originally Posted by Delazy View Post
    yeh your prob right, most cars i buy look rooted
    cb mint buses, makin' them hang is the most ideal choice.
    power
    lock
    weldy
    all thats needed.
    NEAR MISS
  1. Lappy's AE71 daily/drifter
    By lappy in forum KE70 / AE71 Owners Forums
    Last Post: 19th September 2012, 04:44 AM
  2. AE71 4AGE daily
    By ozyvr4 in forum KE70 / AE71 Owners Forums
    Last Post: 14th August 2011, 02:39 PM
  3. My AE71 daily
    By touge_rps13 in forum KE70 / AE71 Owners Forums
    Last Post: 8th June 2009, 07:49 PM
  4. DAILY WTD: ke70/ae71
    By Roku_70 in forum Cars or Parts Wanted
    Last Post: 20th August 2008, 08:37 PM
  5. My AE71 daily
    By asher in forum KE70 / AE71 Owners Forums
    Last Post: 23rd January 2008, 11:33 PM
