Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Which parts in 4AGZE are low comp.
    Justin
    Default Which parts in 4AGZE are low comp.
    Hi Guys
    Sprinter hasn't moved for a few years now, sold my dirty nissan s15, time to get the sprinter back on the road.
    I had big plans for a 4AGTE but I have decided to just get her going asap and not take the time to build it better.
    I have a very tired 4AGE with a flogged keyway in the Crank
    A decent condition 4AGZE (mainly just engine, no manifolds or supercharger)
    My question is, which part of the 4AGZE is low compression, head? pistons? or both?
    Would it work for me to rebuild this engine, and use the head from my 100kw 4AGE and take advantage of the 4AGZE 7 rib block, crank, pistons, rods , and better oil flow.
    I would be using my existing Manifolds and everything.
    Would this be a good high compression engine with a TRD metal 0.5mm gasket? or are the 4AGZE pistons low compression, meaning I have to use the 4AGE ones, and will they fit on the 4AGZE rods?
    Would the 4AGZE pistons clear the 4AGE head with a thin gasket?
    Also while I am at it, anyone know where to get 0.5mm TRD 4AGE gaskets cheaply? also in need of a new Distributer, the sensors inside where used elsewhere, so I have the cap, just need the sensors inside really, so it can be FWD or RWD shaped.
    Thanks in advance for any help
    Justin
    0410101090
    jusdrifn86@gmail.
    If anyone has the time to chat about this on the phone it would be much appreciated, PM me your number and I can call.
    I started the ball rolling...
    Not member #1 anymore
    Yer, the pistons are the high compression part. Others will fill you in with more info.
    Mt Macedon
    The only difference between GZE and GE of a given year is pistons, rings and cam covers. So it's just the pistons which dictate CR.
    However early GEs used smaller big and small end bearings. So if your existing GE is one of them (these included original AE86 4AGEs) then your pistons wont fit on the ZE rods. Pick up a set of later GE pistons and everything will fit fine.
    Also there are basically 2 types of distributor internals, bigport with a 4 tooth wheel and a 24?? tooth wheel, and smallport, 20V etc with 2 single tooth wheels and a 24 tooth wheel. Find whichever you need and go for it. Though I'm unsure if 20V dizzy or internals will physically fit.
    PS, jsut noticed you mentioned you have a 100kw 4AGE now, in that case your pistons will swap fine.
    Justin
    Thanks for your help Hen, answers a lot of questions..
    I now have to be 100% on the fact that my 4AGE is definitely the 100kw version..
    Guess I will do some work on it this Friday and find out the hard way.
    If I was just going to use the same 4age ( I guess it isnt that tired) and just swap the crankshaft for ease of work out of the ZE would this work? if the engine is 100kw so the Big Ends are the right size?
    With regard to the dizzy, My AE82 was having problems and I narrowed it down to the dizzy sensors, the rwd dizzy off the sprinter didnt fit on obviously so i swapped the sensors out and the AE86 twin cam no runs sweet as, so they are the internals i need to replace...
    gay
    n1gger land
    n1gger land
    south korea seoul
    look at port sizes to know if its 100kw or not justin.
    andrew
    do smallport and bigport have the same combustion chamber size ?
    ive only played with bigport heads, i think from memory its 39cc for bigport.
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    I use a similar setup, Bigport head and 4agze block/interanls, if you went this route, i would not recommend using a trd 0.5 head gasket as your compression gets abit to high, I run a standard gasket and my comp ratio is 10:5:1. Goes hard as chippies
    gay
    n1gger land
    n1gger land
    south korea seoul
    11:1 and above is win compression !
    Moderator Sam-Q's Avatar
    Endeavour Hills
    both 16v heads are meant to have the same size chambers, try here for a 0.5mm gasket
    http://www.greenline.jp/
    I suggest just a 0.8mm gasket though, you are talking about turning it into an atmo engine right?
    Jordan
    Sunshine Coast
    Quote Originally Posted by sun_moon View Post
    Thats abit high lol, bring on blown head gaskets
  1. 4AGZE LSD gearbox/shafts and a bunch of 4AGZE parts for sale...
    By mookschank in forum Car Parts For Sale
    Last Post: 9th December 2012, 05:57 PM
  2. 4age Very Low comp on cyl 3 and 4
    By hachirusto in forum Technical - Questions
    Last Post: 28th March 2011, 12:28 AM
  3. 4agze 16v motor low k
    By ca18ae71 in forum Car Parts For Sale
    Last Post: 26th May 2010, 10:50 PM
  4. WTB: get low parts VIC
    By willa in forum Cars or Parts Wanted
    Last Post: 15th August 2009, 04:40 PM
  5. 4agze Problem at low rpm boost
    By DavisJD in forum Technical - Questions
    Last Post: 22nd March 2006, 09:43 PM
